BlackKat's builds
Started by BlackKat, January 17, 2013, 06:03:49 PM
BlackKat
xxx
Pedro-bot
dlearl476
Quote from: BlackKat on January 17, 2013, 06:03:49 PM
The carbon covers are good for 4 hp, right?!  ;D
Regular ones, yes. If they say NCR on them it's 4.9.
Quote from: Pedro-bot on January 17, 2013, 06:40:25 PM
Choice pieces.  [thumbsup]
Congrats.
+1
100 must be broken! :D
Interested what the NCR cam specs are in comparison to oem and DP.
Hershell
2017 Superleggera 1299
2014 Monster 1200S
2013 Panigale 1199R
2016 Yamaha Zuma 50
BlackKat
Well, its going to be tough to give an accurate comparison..
Currently, big bore and a bunch of bottom end goodies.
DP cams
stock heads
DP ECU and Power commander 5
Shows 98.7xxx hp
however, when I make the swap, there's a bunch of factors.
I'm switching to the Guy Martin cast intake manifolds that are 4+ mm larger
Kibblewhite big valves
some port matching and cleanup by Fast Frank
the DP cams are obviously swapping to the NCRs
Getting rid of the DP ECU and PC5 and switching to a Microtec
I better EFFIN break 100!
BlackKat
#6
xxx
brad black
what happened to the front fork travel?
Brad The Bike Boy
http://www.bikeboy.org
BlackKat
#8
xxx
jimbonuttz
there's a paul smart sitting in my living room...definitely a great rendition from a monster!
qd xbox exhaust, cw fender eliminator, 14t sprocket, 6k hid, rizoma (front axle slider, rear axle slider, naked prototype mirrors, sports grip, bar ends), speedymoto top triple, woodcraft 3" riser clipons, battery tender
that rear wheel is really cool! im not a fan of spokes but its still cool as hell!
The Don
That bike looks unreal, well done [clap]
Wise men talk because they have something to say; fools talk because they have to say something. - Plato
BlackKat
#12
xxx
geoffduc
Quote from: BlackKat on January 29, 2013, 05:28:04 PM
haha...That was what happened when you strap a bike tightly in a trailer when its well below 0 degrees...it takes a few minutes to warm up again...
...Thats what you noticed from all the pics!
Firstly let me say how good the bike looks... [bow_down]
those wheels really make it work and I'm sure that when Ung see's it he probably cream himself... [clap]
Now on to the strapping down issue, I deliver bike all over the the UK by van and have also been the WDW three times with bikes in the back and touch wood I've never had any issue's with the stability of the transported bikes.
I never pull the front down tight but prefer to use two straps on each side to the centre and rear pulled tight and another strap on the bottom of the forks just to hold the wheel in place, when you see bikes that have had  their fronts racheted down hard and the seals burst you'll under stand why I do it my way.
Well thats my 2 cents,sorry to jack the thread but again may I congratulate you Sir on a great looking bike... [bow_down]
Geoff... [coffee]
2015 scrambler FT
2009 monster 1100s
BlackKat
#14
xxx
