February 24, 2025, 12:03:47 AM
Painting a clutch plate?
Topic: Painting a clutch plate? (Read 909 times)
hyflight
January 22, 2013, 06:25:20 AM »
If I install the pressure plate linked below, can I paint the first clutch disc that would still be visible? I'm new to Monsters (2010 1100) and have not gone inside the clutch yet. Can I just slip off that first plate? If it's okay to paint, any suggestions on a quality spray paint? Any other thoughts/advice?
http://www.motovationusa.com/mvstore/Scripts/prodView.asp?idproduct=1714
Thank you in advance!
Re: Painting a clutch plate?
January 22, 2013, 06:33:16 AM »
I wouldn't recommend painting.
It will just wear/burn off, and may cause slipping.
Omnipotent Potentate
Personal Pretext
January 22, 2013, 06:44:15 AM »
The exterior of a dry clutch pressure can be painted. Run a search and you'll find folks who have done it. Do not paint the back side.
As DP said, don't paint any of the plates that for the plate stack.
