February 24, 2025, 05:45:59 AM *
News: Please Help
Author Topic: Speedymoto Top Triple Install Issue  (Read 2480 times)
eltoshan
« on: January 26, 2013, 10:42:15 AM »
Hey guys,
I'm in the process of installing the Speedymoto top triple on my M796.  The stock top triple is off.  Now my problem is installing the headlight brackets.  My top triple came with roll pins in what I assume to be threaded holes for the stock bolts and vibration dampers to go into.  Do I need to remove the roll pins for the install or am I missing something?
Thanks!
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #1 on: January 26, 2013, 03:29:27 PM »
Yes, you need to remove the roll pins.
This might help you  >>  http://www.ducatimonsterforum.org/index.php?topic=21407.msg447867#msg447867
This is worth a read too  >>  http://www.ducatimonsterforum.org/index.php?topic=61265.0
« Last Edit: January 26, 2013, 03:44:08 PM by ungeheuer » Logged
slvrflme147
« Reply #2 on: January 26, 2013, 03:55:07 PM »
I just did this install a few weeks back and had to buy a pair of 5x20mm bolts.   After removing the rolls pins I used the 5mm bolts and some loctite to mount up the headlight brackets.   I also had to grind down a hex key to tighten the center bolt by the steering nut.   Only way I could get at it,  even after tearing the tank and key guard off.
2011 m796
tail chop, rizoma reverse retro mirrors & barends, Woodcraft 2.5" clipons, speedymoto top triple, Lux grips, carbon canister delete, HID light swap, barracuda turn signals,SC Project 2-1 exhaust, random powdercoating and carbon
jimbonuttz
« Reply #3 on: January 28, 2013, 10:04:23 AM »
yep ^ that's the way to do it! i did mine a couple weeks ago as well...
qd xbox exhaust, cw fender eliminator, 14t sprocket, 6k hid, rizoma (front axle slider, rear axle slider, naked prototype mirrors, sports grip, bar ends), speedymoto top triple, woodcraft 3" riser clipons, battery tender
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #4 on: January 29, 2013, 12:59:37 AM »
If you back off the steering stops its possible to turn far enough to get access to the bolt near the steering head.
hunduc
08 S2R1K
« Reply #5 on: January 29, 2013, 05:09:39 AM »
how did you remove the pins? just yank them out with pliers?
DucNaked
« Reply #6 on: January 29, 2013, 07:20:06 AM »
I clamped the pins one at a time in a bench vice and pulled on the triple. They came out without much effort.
freeclimbmtb
From Zero Member to
« Reply #7 on: January 29, 2013, 11:10:04 AM »
Thats what I did.  Vise grips I think actually..
I also ran a tap from the top down through the holes to chase the threads into the roll pin section of the holes.  I feel like I had hardware left from removing the old triple that I was able to use to secure the new stuff...I dont recall having to buy any bolts.  (I did the swap at a friends house and I know I didnt have to make any special trips out...)
2011 Monster 796 ABS
eltoshan
« Reply #8 on: January 30, 2013, 07:08:02 AM »
I tried to remove the roll pins with vice grips yesterday, no success. Tried pin punches with a hammer too. I'll give a bench vice a shot tonight. Hopefully the pins come off!
jimbonuttz
« Reply #9 on: January 30, 2013, 10:04:26 AM »
i tried the vice grip method and it didn't work for me either... i used a punch from the top (making sure not to hit the thread by shining a light inside to see where the edge of pins were) and smashed it with a hammer numerous times and it finally came out.. if you hit the thread you can always re-tap it.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #10 on: January 30, 2013, 02:35:16 PM »
I used this method too.  Roll pins came out quite easily.
