Battery Tender
Started by MsTek, January 27, 2013, 01:20:44 PM
MsTek
Apologies if this is in the wrong place.  Mod, please move if needed.
So I am a bad owner.  My bike has been sitting in the garage and not ridden for a very long time.  For giggles I went in to see if the batter would kick over- it is lighting the gauges and all that fancy stuff but no juice to turn the engine over.
The fact that it does light up bright leads me to think that if I can try to put this battery on a tender within the next two days, I'll be okay.  I happen to have battery tender but I am not confident I won't burn down the garage I rent or damage the bike.  I hear that I can keep the battery IN the bike and just connect the round connectors to the to power and then I don't have to take the battery out of the bike or off its own power.  Is this true?  Can I do this without burning down the garage?  I rent this garage so I am going to have to unplug the automatic garage door thing and put in a power strip so I can connect the connector.  I think I am smart enough to figure this out with a little guidance from the people here, if you would be so kind as to direct me.
Just want to be sure I can ride as soon as it is warm, instead of being upset I didn't put the battery on the tender when I saw it was going to be bad.  I think I can still save it...  Help? :)
"Do something each day that scares you..."
skurvy
#1
You'll have no problems. I had my bike hooked up to a battery tender for about year and it didn't even pop a fuse, started right up.
Yes you can use the round connectors so the battery stays in the bike while hooked up. Just connect the round connectors to the +/- battery terminals, then the quick connector can be accessed through the frame. Then it plugs one way to the battery tender.
I think the only problem you might have depends on how old the battery is, it might not hold a charge even if it gets recharged by the battery tender. I got 4 years out of my last battery and it sat for 1 year plugged to the tender.
ffwd to 2:00 for the quick connector:
MsTek
DuciD03
Soooo-dit work for ya?
I'm using a jr tender; works great; typically you'd like to keep a battery fully charged; topped up; or its hard to get it fully charged again.
[Dolph] Cheers DD
.... all the world is yours.
oldndumb
I noticed that the video shows a BatteryTender installed on a Shorai battery. That is not the recommended charger for a LiFe battery because it will not allow a full charge.
http://shoraipower.com/faq
