February 24, 2025, 03:28:00 AM
Cut slots in front fender
Topic: Cut slots in front fender (Read 3124 times)
uclabiker06
"The time you enjoy wasting isn't wasted"
Re: Cut slots in front fender
Reply #15 on:
February 02, 2013, 09:43:28 PM »
Whats are the correct dremel heads needed for the job? Any tips on sanding? I'm just going to leave it raw I think, so no coating or paint. The ends of the oval are what I'm really worried about because it will curve...this is going to be "labor intensive".
Last Edit: February 02, 2013, 09:49:21 PM by uclabiker06
2006 S2R
2009 Smart
Reply #16 on:
February 03, 2013, 12:45:56 AM »
in my experience with dremel and plastic, high speed=melting
Reply #17 on:
February 03, 2013, 01:26:01 AM »
And melting = flinging molten plastic all over your unprotected skin...
uclabiker06
Reply #18 on:
February 03, 2013, 11:07:51 AM »
I guess I'll wear dishwasher gloves or something. So the fender is plastic? Its not fiberglass is it?
2006 S2R
2009 Smart
memper
Reply #19 on:
February 03, 2013, 04:53:59 PM »
Yes, of course wear proper safety gear.
Another route (didn't know yours was plastic-wear a respirator for sanding) is after you have the design drawn on you can perforate it along the line with a small drill bit. Shit, after that you could use a coping saw and not have to worry about hot plastic at all.
Reply #20 on:
February 03, 2013, 09:56:28 PM »
Quote from: uclabiker06 on February 03, 2013, 11:07:51 AM
not sure when plastic vs fiberglass happened. my fender and bodywork are that plastic stuff, probably ACERIBIS or something
