February 24, 2025, 05:44:55 AM
Cut slots in front fender
Topic: Cut slots in front fender (Read 3127 times)
uclabiker06
"The time you enjoy wasting isn't wasted"
January 31, 2013, 01:51:56 PM »
Hello to all, haven't been here for a while. Thinking of cutting some slots in my front fender; exposing more of the front tire. Took the fender off but didn't like how it looked and don't really like how it looks on normal way either so I figured to make some nice cut outs. Any advice on how to go about doing this? Thanks & cheers
Last Edit: January 31, 2013, 01:58:55 PM by uclabiker06
2006 S2R
2009 Smart
memper
Re: Cut slots in front fender
January 31, 2013, 04:34:39 PM »
Do different designs with cut paper and scotch tape. Once decided use a dremmel and go slow. Finish with hand files.
uclabiker06
January 31, 2013, 05:21:55 PM »
That will work but i think the shape would have to be pre cut because I don't think it will come out even with scissors. Is there a more accurate way of doing it; just wondering. Thanks
Last Edit: January 31, 2013, 05:25:58 PM by uclabiker06
2006 S2R
2009 Smart
Omnipotent Potentate
Personal Pretext
January 31, 2013, 05:40:27 PM »
Xacto knife and French curves?
uclabiker06
January 31, 2013, 09:46:25 PM »
Insteresting, but I was thinking more of a elongated ellipse. Perhaps that would be easiest. Trying to keep it simple here. Don't know if I have the dremel skills/dremel heads to pull even that off though Boy oh boy.
Last Edit: January 31, 2013, 09:51:48 PM by uclabiker06
2006 S2R
2009 Smart
memper
February 01, 2013, 05:21:18 AM »
Make the oval in Photoshop or similar so you know its perfect. Still do the paper cut out with an exacto and take your time. Mark the fender centerline with a metal pencil or a crayon. Fold the oval to find the centerline. Trace onto fender. Cut with the dremmel but cut on the WASTE side of the line. Sanding tips and hand files can take care of the rough cut. Take a chance, take your time, you will be fine.
freeclimbmtb
From Zero Member to
February 01, 2013, 06:07:08 AM »
Quote from: memper on February 01, 2013, 05:21:18 AM
I could see this going terribly wrong.
2011 Monster 796 ABS
Dirty Duc
I'd rather be an anti-
February 01, 2013, 09:33:33 AM »
You want a broken one to practice on? one of the "legs" is broken (fatigue), but it's yours for shipping.
Ducatis on the Salt
uclabiker06
February 01, 2013, 06:48:32 PM »
Nah, I got good nerves, almost of steel. Pics promised if I actually do it. Due for another project; keep my mind from wandering...I think tracing the outline might be a tad difficult since the surface is slick clear coat; will "steal pencil" work?
2006 S2R
2009 Smart
Dirty Duc
February 01, 2013, 07:16:57 PM »
Quote from: uclabiker06 on February 01, 2013, 06:48:32 PM
That has never worked for me
Ducatis on the Salt
uclabiker06
February 01, 2013, 07:40:51 PM »
Just hope that the opening in the fender doesn't let grime from the tire get all over the underside of the fronte end. Maybe I should keep the opening small, I don't know
Dirty Duc your last comment perhaps proved your first profile quote.
Last Edit: February 01, 2013, 07:43:21 PM by uclabiker06
2006 S2R
2009 Smart
Dirty Duc
February 01, 2013, 08:21:57 PM »
Quote from: uclabiker06 on February 01, 2013, 07:40:51 PM
[\quote]
Only cut in the middle on the front half... most of the spray comes off the center of the tire (mud or water)
I guess that depends on where you are trying to keep you mind from wandering! The good idea fairy is a regular visitor to my head.
Ducatis on the Salt
February 02, 2013, 02:22:09 AM »
I don't think grime will be an issue. I run no fender at all...
dlearl476
February 02, 2013, 08:57:18 AM »
Quote from: freeclimbmtb on February 01, 2013, 06:07:08 AM
Thats why we have a parts wanted/parts for sale section.
I bought another air box/battery tray before I took the Dremel to mine to make way for the UNIs.
uclabiker06
Reply #14 on:
February 02, 2013, 11:39:44 AM »
Thanks Nakid
2006 S2R
2009 Smart
