oil filter socket fitment
Started by dolphaxel, February 02, 2013, 07:43:41 PM
Ddan
Ducati Monster Forum at
www.ducatimonsterforum.org
The rule is hand tighten, but not crazy much, except we all have varying degree of how tight we can ge it by hand.. But for threads like that, i say without too much force until the thread stops, then add 1/4 turn to it by hand. THe heat cycling and crud will usually keep it on there afterwords without loosening up.
so i never used one for install. only to remove.
Quote from: He Man on February 03, 2013, 10:28:54 PM
+1
Never had a leaking issue with a hand tightened filter...
brad black
Quote from: dolphaxel on February 03, 2013, 12:09:06 PM
http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=648943&group_ID=675601&store=&dir=catalog
lordy lord, snap on made in china.
the big multigrips don't fail, and it matters not what the old filter looks like.
i can tighten them past 11nm by hand, but it's a two handed effort.
Brad The Bike Boy
http://www.bikeboy.org
desmodoktor
I use k & n oil filters for my bikes...
When I was using the Ducati filter I had hard time removing it
Cos I couldn't put any socket or strap tool around it bcoz the exhaust pipe was
On the way ... Also I couldn't tighten it all the way by hand so it was leaking ..
The kn filters come with a 17mm nut welded on the bottom .. and that made my life easy...  And It's 5-6 $ cheaper :))
IG @desmodoktor & @ridingturtlegarage
alibaba
Howie wrote:
"Some of us (me) also sometimes call them water pump pliers.  "
You are dating yourself Howie.    ;)
dolphaxel
well changed the oil tonight. Only filter tool that I have to for this stupid thing was a screwdriver and a hammer. Came off really easy though. Now it has a K&N and the problem is solved. Next time I'm waiting more that 5 min to drain the oil after a ride though. Damn that oil was hot. the temp was at 195 right before I killed it. [thumbsup]
2003 m800 S.I.E.
Quote from: dolphaxel on February 09, 2013, 06:48:13 PM
Told ya it'd work [thumbsup]
JoeB
Slightly OT, but is anyone using the Amsoil filters at all?
Ddan
Quote from: JoeB on February 11, 2013, 01:40:43 AM
I am.  It's a good filter
monsteronfire
hy new on this forum  and really want to know  what kind of oil filter my bike use is a  monster 900sie 2002  and the best oil and the viscosity .. any web page to look or order thanks  [popcorn]
Ddan
Quote from: monsteronfire on April 21, 2013, 08:59:40 AM
http://www.ducatimonsterforum.org/index.php?topic=1912.0
