super expensive, high end, handmade clutches?
Started by showerfan, February 05, 2013, 03:23:05 PM
showerfan
anyone remember the name of the company that makes those super expensive, handmade dry clutches? company has two names like magnavox & branson or something, and the website looks more like a piano maker or some high-end audio gear website. but i want to do a story on them.
Give me a shout if you know any good motorcycle detailers in the Westchester area.
JohnEE
Quote"HOW A DRY CLUTCH CAN GIVE YOU WET DREAMS"
Testimonials
If you don't include that quote in your story i'm going to be severely disappointed.....
showerfan
yes, wagner lewis! anyone have any thoughts on their claims?:
``The unique patent-pending stabilizer plate in the Wagner Lewis Lightweight Pro Clutch is the key to a clutch that works better longer. The CNC machined stabilizer plate in conjunction with other precision components allows your dry clutch to function perfectly. but it prevents the clutch plates from hammering the basket. The benefit to you is better feel and longer life. No matter how hard you use it, or how much you slip it.''
http://www.wagnerlewis.com/
makes sense. stabilize the end of the basket by centering it using one of the inner friction plates and a outer plates oversized notch area.
showerfan
Mr. Lewis (of Wagner-Lewis) was in my shop (Flight Cycles) years ago trying to get me to 'demo' a unit but I didn't have a project to install it on @ the time...
Kinda wish I had found something to install it on in hindsight.
TitanMonsterS4R
Tricknology
I'm really digging the finish on the pressure plate. That thing is gorgeous.  :o
'02 Monster S4 "Senna" - - Slowly getting closer to the ideal I have in my head.
'02 Monster S4 "Senna" - - Slowly being parted out
The Don
Quote from: showerfan on February 05, 2013, 08:33:53 PM
on the home page there is a image of the ducati flat tracker, I never noticed before that the engine in that chassis is rotated backward. just an observation, carry on
Wise men talk because they have something to say; fools talk because they have to say something. - Plato
Bishamon
Quote from: The Don on February 06, 2013, 03:20:05 PM
I noticed that, too.  Interesting.
I wish I still had a Duc with a dry clutch so I could buy one of those hand made beauties!  Oh, and an extra couple of grand lying around.  ;)
2011 Monster 796
2007 Sport 1000 SE (SOLD) :(
chris1044
It's rotated "backwards" to get the horizontal head out of the front tire's way.  If they don't do this, they can't get the correct suspension geometry (rake) for the track.
Probably helps with centralizing the mass somewhat as well...
And likely helps the swingarm and chain interference
Yeah, it's expensive, but if you nver have to replace any parts....
Quote from: Tricknology on February 06, 2013, 03:09:36 PM
The pattern isn't anything unique - several manuf make plates with that same milling pattern. But the effect of the Type 3 ano is nice.
