Let there be light! 796 LED headlight project <pics>
Started by Stormtrooper, February 07, 2013, 04:44:09 PM
Stormtrooper
Never being too fond of the stock headlight, I wanted a replacement that was more industrial and technical.  The stocker is just too "cartoonish" for my taste.  It had to look trick yet be functional and aggressive at the same time, and it had to be LED.  This is what I came up with...
The technical stuff...
The headlight itself is an impressive piece of kit.  It's a Rigid Industries Dually D2 and is usually found on off road vehicles, boats, and ATVs.  I can tell you it's bright as hell!  It makes HIDs look washed out and dim in comparison.  Its rated to 2600 lumens @ 28 watts in a 1lb package.  6 high powered LEDs at only 1.9A make it all happen.  They actually just released a 36W 3030 lumen version...whoa!  Compare that to 1200-1500 lumens at 55W for our stocker.  No bulky ballasts, igniters, or wiring to hide as well = compact and clean.  The housing is extruded aluminum and is basically a large heatsink.  I hooked up the LED with an OEM harness connector (thanks Eastern Beaver!) so the whole thing is plug n play with no cutting or splicing of the factory harness required.  Matte white to match the bikes colorway and to contrast with the carbon :)
Originally ordered a black version and did a quick mock up...
The mounting would not be possible without this trick CNC bracket from Crime Scene Choppers (http://www.crimescenechoppers.com/)  Yes, a "chopper" shop made this!  Based on my measurements and diagrams they CNCd me a prototype that fit perfect the first time.  It mounts on the factory tabs on the lower triple and can fit just about any compact headlight that has a mounting point on the bottom.  This is much more ideal IMO than the ghetto fork strap mounts that are widely used.  I designed the bracket so the headlight would be recessed in the forks as much as possible to avoid that "buck tooth" look of the headlight sticking too far out.  I can't say enough about Crime Scene, they were a pleasure to work with and said they would be willing to make more if there is a demand.  They made two of these so I know they at least have 1 left...
the mess before the wire cleanup...
Note: I am only running a single LED headlight, not a low/high beam arrangement.  The LED is so bright it is like running a high beam at all times.  It took some careful adjustment to aim the headlight as to not blind oncoming traffic but still be high enough to project far enough down the road.  This LED is not DOT approved.  The mounting bracket I designed is capable of running 2 of these D2 LEDs stacked, but it would lumen overkill in my opinion.  I almost went with a LED lightbar from Rigid instead but settled on the more compact D2.  Another option is to wire the light to power on at say 70% for low beam, 100% for high beam if you MUSt have high/low.  Again, I didn't bother with this and I am pleased with the results.  Since the LED is wired to the high beam wires my indicator is lit all the time but I can selectively turn the headlight off now with the high beam switch and run "stealth" if I feel the need :)
Oncoming point of view compared to my Navigator with OEM HID with 6K bulbs...
Off center oncoming comparison between our Leaf (OEM LED low beams) and the wifes SRX (OEM HID).  As you can see, the D2 is incredibly intense.  Pictures dont really do it justice, you have to see it in person to believe all this light comes from this tiny cube...
Not the best pictures but you can at least see the razor sharp cutoff and beam pattern.  These are the "Driving Beam" versions FYI...
Other mods...
As you may have noticed, there is plenty of carbon fiber on the bike.  In addition to the fork shrouds, the LED headlight "winglets" as I call them are simply there to add some style to the package.  I angled them to match the line of the cluster and forks and give everything a more raked, aggressive look.  I actually got the idea from the rear stabilizers on RC helicopters lol.  Removing the OEM headlight meant I no longer had a way to mount the instrument cluster and turn signals.  Oberon LED bar end indicators solved one problem.  For the cluster, I fabricated custom aluminum brackets to bring the assembly down as much as possible providing for a much cleaner profile.  The shrouds extend to the rear monotube as well :)
Excuse the lack of exhaust...NO I don't ride like that normally!  I am right in the middle of my exhaust project...stay tuned!
Ohmic
Very nicely executed [thumbsup]
You might want to have someone ride your bike at night and you lead in a car to make sure the intensity is not blinding from the rear view mirror.
'It's NOT a Harley... It's a Ducati!'
Bike#1: 2002 Ducati MH900e #1801
Bike#2: 2006 Ducati Monster S2R1000
Bike#3: 2006 Ducati Sport1000
Bike#4: 2008 Ducati HyperMotard 1100
joshuajcrouch
Not my style... but damn impressive!  Nice job thinking outside the box.  I can tell you put a lot of effort into the planning.
I actually think the black housing would look better on the headlight.
Heath
Any pictures of it at night shooting against a wall to see the cut off?
2007 Ducati Monster S4RT
Anchorism
Not exactly what i would do to my bike but I do like it!! Very sharp and unique. Nice looking bike you got there.  Got a few features that im waiting to do to mine.
"Life's tough.  Its even tougher if your stupid!"
-2011 Ducati Monster 796
-1985 Moto Guzzi V65TT
   Knobby tires
JohnEE
My main critique with the new monsters is the head light. It just looks wrong IMO. You have definitely come up with a unique solution! Looks great. Great Job on the mounting.
memper
I like it a lot. However I would cut off the corner tips on the front of your carbon mounts.
xsephirot
 [thumbsup] Great job! I liked how you did everything so clean and to the way you wanted. I'm still trying to figure out a way for me to fit brighter headlights for my S2R. Was trying to decide between HIDs or the trucklite LED and now you may have convinced me to look into these. Though I'm not sure I could do as clean as a job as you did.
Is the headlight just mounted on 1 point on your custom designed bracket or is it also mounted to the 2 carbon fiber winglets? I'm wondering if theroetically I can mount 2 of these side by side using the original U bracket.
Bishamon
2011 Monster 796
2007 Sport 1000 SE (SOLD) :(
Gossamer_in_FLL
 [clap] [clap] [clap]
PHENOMENAL!!  You know the old adage "imitation is the best form of flattery"??  I'm about to half compliment you (l'll make my own version of your winglets thankyouverymuch).  This is exactly what I was looking for.
Hopefully I can lean on you for some help through the process.
Great job!
greenohawk69
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty:  Soap, Ballot, Jury and Ammo.  Please use in this order.  -- Ed Howdershelt
greenohawk69
I have a '97 M900...and have been looking at upgrading the light and am very interested in the work you did.  The bracket from Crime Scene Choppers...are you aware if it would fit my year / model bike?  Might need some measurements.  Also, you mentioned...Beaver... [laugh], I digress, can you show this OEM adapter you mentioned.
SpikeC
 What a cool installation! As I am a confirmed Luddite, I would install that unit inside of a 36 Ford spotlight bucket! I do dislike the headlight that comes on the monsters and have been thinking of alternatives, this opens up a whole new realm of possibilities!
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
