machining a stock flywheel
Started by ollie, February 09, 2013, 09:04:41 PM
ollie
I'm keen to get a lighter flywheel for my 2005 620. I've heard that a machined stock wheel is pref errable over an alumin aftermarket unit.
Two questions:
Are flywheels model specific, I'm going to try and find a used one on eBay, does it need to have come off a 620, or will other wheels fit also?
I will get a local machine shop to turn it down, has anyone got the required dimensions to slim it down to?
brad black
i machine them down to 120mm od and around 13mm thick (from memory) at the outer edge.  makes them about 880 grams.
Brad The Bike Boy
http://www.bikeboy.org
ollie
Thanks brad, that's exactly what I needed. I was going to try and find a second hand one
Are they model specific?
brad black
only 749 and 999 are different afaik.  they have a small oil squirting hole to spray the alt stator
Brad The Bike Boy
get in contact with forum member monsterlover
Quote from: Darkmonster620 on February 10, 2013, 03:00:21 PM
shipping will kill the deal. ;)
Quote from: ducpainter on February 10, 2013, 03:03:42 PM
you are right . . . but, someone could send ml a stock flywheel and ollie send his as a "trade" . . just saying . . . .
Depending on the size of the package. I sent a clutch hub out to Australia for $12 bucks from USPS. It isnt all that bad.
Nibor
It's the other direction that screw us Aussies. Cost me $120 to ship two brake discs to china. A flywheel to USA would be like $50!!
Thanks for the mention :)
If it fits I have one already done from an injected 900.
ollie
