February 24, 2025, 03:26:58 AM *
Author Topic: Front Axle Compatibility ?  (Read 976 times)
Real Recognize Real
« on: February 21, 2013, 03:55:21 AM »
I've searched the forum and cannot find a definitive answer to the following question:
Will a front axle(non-adjustable fork) work with adjustable forks? I have an axle from '94 M900 and acquired adjustable Showas from '99 M900. I believe both forks have the same diameter (17mm).
Would someone chime in or provide a link that addresses this issue?
Don't argue with idiots. They'll drag you down to their level and beat you with experience.
MotoPsycho
General Nuisance and a
My Dream, my rules !
« Reply #1 on: February 21, 2013, 05:11:52 AM »
17mm is 17mm as far as I know. That's the route I would go. You could even use forks from the SS's that have the same axle size as long as they're the 50/54mm typical of that era of bike. 851/888 forks are the same size too I believe.
Real Recognize Real
« Reply #2 on: February 21, 2013, 05:51:21 AM »
Thanks for the info GRUBBY. I thought that was probably the case, but I wasn't completely sure since I recall reading another fork swap thread that mentioned drilling a hole in axle to accommodate rebound adjustment. I wondered if I would need to do the same for my existing axle.
