February 24, 2025, 03:24:48 AM
696 guys please help..
Topic: 696 guys please help.. (Read 1236 times)
cactus-pits
February 21, 2013, 05:08:06 PM »
I'm trying to remove my entire factory exhaust and under the seat where the Y thing is connected, the right side had a nut and the left side has a different type of attachment..I need to lift the tank etc to get an Allen wrench in there and I can't get to it..is there an easy way to do this?
cyberswine
I Just Washed and Waxed my
2011 796 ABS
Re: 696 guys please help..
February 21, 2013, 11:42:51 PM »
No "easy" way to lift the tank on the new gens but then it's not difficult either, just time consuming. When the fairings are off the tank and the right side banjo bolt is removed there is just the one Allen bolt under the tail end of the tank assembly. You get to it from underneath, just above the "Y". Then you can lift the tank and swing it out without disconnecting the fuel lines.
"Life ain't no box of chocklits when you is born a idiot"
Forrest Gump
danaid
February 22, 2013, 10:06:34 PM »
With the tank off its also easier to get a tool in to reach the o2 sensors and the vertical cylinder flange nuts, if you haven't done so already.
Ceramic coating your exhaust?
11' 1198SP Black
09' 1100S Red
09' 696. Red first Ducati (sold)
cactus-pits
February 25, 2013, 05:13:26 PM »
sorry guys..I panicked!..got everything off..didn't remove the tank completely but just propped it up out of the way..and viola, full access to all that shite..boom tubes will be here tomorrow..
