Is anyone familiar with a 1985 Harley-Davidson Sportster XLX
Started by eichh, March 01, 2013, 06:31:22 AM
eichh
I came across a 1985 Harley-Davidson Sportster XLX for $3000 in the area and it looks to be in great shape from what I saw in pictures on the dudes phone. The top half of the engine has been gone through such as pistons and what not. I will go look at it on Sunday and buy it if all is well. My question is what should I look for on this year and make of bike? Harleys are new to me but for the price its perfect to get cut up and turned into the cafe/brat/board track looking bike ive always wanted to build. Aside from the "its a Harley" comments does anyone have any experience and knowledge about this model? I dont have any pictures to post of it.
Thanks,
Erik
muskrat
make sure the cylinders are both firing, I've heard they some had issues.  Also, clutch cable and oil leak around the transmission.  Not giving you a hard time as I too have a Harley albeit an 09.  I would offer 2500 if it were me and rest assured there are parts galore.  You wouldn't believe the after market on these bikes.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
If you can strip off enough weight, it might be interesting. But it's a 540 pound bike, rated at 49 hp (when new) and a 4 speed trans. In it's present configuration, it's going to feel ver short legged.
eichh
Thanks,  I will shoot the cylinders with a temp gun to check for inconsistencies I'm looking to do something similar to this setup.
http://s201.beta.photobucket.com/user/chiflado/media/8f60deb9c2bdd19bf77e2cb242661acf.jpg.html
So im going to strip it as much as possible, its been punched out with 10:1 pistons and cams but its still going to be a dog next to the Duc or Busa. It does have the standard issue oily discharge but low and slow might be nice every once in a while. Here's what it looks like now.
xlx by erik.eichhorn, on Flickr
muskrat
who cares if it's slow, purpose is what you're after.  Good luck and post progress pics, maybe I'll get inspired.
2015 MTS 1200
09 Electra Glide
eichh
Progress so far.
I made a 1/4" steel jig to hold the frame square and in place while i cut the frame.
I then lowered the frame rails 3 1/2" and removed the jig.
The last photo shows the small rear fender that will be welded to the frame so there wont be any seams.
I put some plate steel on the frame rails that drop down where the oil tank used to be since I wont be running a traditional fender, just to keep chunky chow from flinging all over the new oil tank and electronics.
I got tons of welding to get done today and will post again once the sheet metal work is done.
So far so good I love the way I sit nice and low.
You'll have fun.
Still an iron head in 83. They went to alloy on the sporty in 85? Cant remember because I was there! Better run an oil cooler, cant tell on my phone if it has one. Make sure the genny is working well. I had a 75 model, you could cook your dinner on the heads in summer. These things had a form of cassette type gearbox. Was it a Trog or Troog gearbox "door" you could get?
With high comp you need an oil cooler unless you live in Alaska. Use the correct ,high quality oil.
I still want to find an XR or KR 750 in some farmers barn..
Ive had three Harleys, but the Sportster was the most fun..
Memories.
Speedbag
I like where this is going.  [popcorn]
Ironhead engine was around until the '86 model year.
+1 on the oil cooler.
eichh
Ok the fender is all welded up and the turn signal holes are drilled. Next I need to find out how small of a lithiun battery I can get away with. I am short on room so its between the 8 or 12 cell. I had an 8 in my S4 Monster that worked great, I believe the 8 had 210 cca and the 12 had 510 cca or something like that. I cant imagine this motor is harder to turn over than the Monster right? Once the battery is figured out the welding is done and I can get some paint on it and begin to rewire it. I picked up a Badlands module so I can use the 2 rear light as running, brake and turn signals. Let me know your opinions on the battery. It has a tiny oil cooler on it but I was thinking I can configure one to be incorperated with the front scoop thing that goes in the front of the bike twards the bottom of the frame. I dont know what they are called exactly besides a front scoop thingy I figure heat sinks can be added and possibly hold another 1/2 to full quart of oil if I design it as a crazy shaped oil tank. I have to do some research on that first.
Speedbag
Kev M
Quote from: eichh on March 17, 2013, 07:57:30 AM
BIG heavy crankshaft/flywheel assembly, knife-fork rod assembly, staggered cylinder timing means it takes a lot of amps to start cranking over a Harley motor. I get the impression our Duc spins up a lot quicker/easier than our Harleys have.
I too would say go with the bigger battery.
Current Fleet
18 Guzzi V7III
16 FLHP (Police RK)
13 Guzzi V7
11 M696
not to second guess your work which is really cool.
but have you thought about making your seat/fender into the actual oil tank and get rid of that round tank?
and be able to fit the larger battery
SpikeC
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
Speedbag
Quote from: Kev M on March 18, 2013, 10:54:31 AM
Yes, again.
I recall reading once that stroker big twins can require as much cranking power as a small block Chevy V8.
You have a stock ironhead Sporty, but the facts mentioned above remain. These are beasts to spin over, as any kick-only Harley owner (myself included) will attest to.
