November 26, 2024, 10:44:54 PM *
Pages: [1] 2   Go Down
Author Topic: open clutch cover  (Read 3870 times)
dmb80
« on: March 02, 2013, 05:28:01 PM »
hi all
has any here installed a open clutch cover on a s2r 1000 if so are they hard or easy.
is it a matter of taken off the original cover and just replacing with a open cover or is
it more complecated than that.
Two dogs
« Reply #1 on: March 02, 2013, 06:38:53 PM »
An S2R1000 here
Easy ....... basically unbolt cover and replace ..... BUT unless you replace the springs with SS
ones it they will rust and look  vomit
Up to you if you replace the pressure plate plenty of cheap ones from China but they look that
cheap and the ano usually fades.
If $$ are an issue you could clean it up and spray the OEM with VHT high temp paint.
But worth at least replacing the springs and buttons.
Some sort of protective cage over the clutch assembly would be advised for protecting the clutch from foreign bodies entering the melee .
Dez
hambo
« Reply #2 on: March 02, 2013, 09:11:51 PM »
just dont do it up too tight or you squeeze the rubber ring inwards and it can touch the plate .....otherwise pretty straight forward
have fun
« Reply #3 on: March 03, 2013, 11:28:24 AM »
Police are hammering open clutches down here in Vic. Whats it like where you are? Maybe a vented cover like a Corse type. Interestingly, my mates Superlight has a Corse type vented cover oem.
Sundog
« Reply #4 on: March 03, 2013, 08:18:36 PM »
Really!!?? Anecdotal or personal experience there koko? I live on the Mornington Peninsula and it's bike central here on sunny weekends with lots of marked and unmarked cars and bikes everywhere in the around the vineyards but even though I've had a DP open cover for over 2 years, I've never had a problem with Mr Plod in the times I've been haras pulled over. Is this some new policy or blitz?
M1100 2010 in Ducati Titanium Grey
Custom Wizard Sleeve pipes & PC5 with O2 opt
14T Front
DP Anodized Pressure Plate DP Tail Chop
DP LED Indicators               Rizoma Rearset & Mirrors
Oggie Sliders                     Rizoma Bars & Levers
« Reply #5 on: March 03, 2013, 09:36:57 PM »
They have been targeting tail tidies and open clutches in the Dandenongs and Yarra Ranges.  bang head . I put my beer tray, reflector and stock clutch cover back on. Have left me alone for it since. You can forget the two Spurs on the weekend.  Its well known and the bike shops sold rear guards like hotcakes.
More chilled cops down the beach? laughingdp
« Last Edit: March 03, 2013, 09:38:54 PM by koko64 » Logged
dragonworld.
I can make like a tripod with my.....
« Reply #6 on: March 04, 2013, 03:52:43 AM »
Vented clutch covers?? WTF Shocked
Yep thats gunna do a lot for the road toll!  Roll Eyes
Rowdy
S4R
« Reply #7 on: March 04, 2013, 12:58:51 PM »
hi all
It's really easy. Just unbolt the one you have on at the moment and have a look inside your clutch. They run a dry clutch so no oil or gaskets. There is a rubber seal between the cover and casing that needs to go back on the correct way and some bolta are longer than the others. Just take your time and make a note of how stuff comes apart.
All up, to take your OEM cover off, have a look inside then bolt a new cover on will probably take you less than five minutes. Longer if you spend more time looking at your clutch.
Do note that once you start taking bits off and replacing with new, bright shiny pieces, there may be no end in sight.
You greatly underestimate the amount of overconfidence I have.
Betty
« Reply #8 on: March 04, 2013, 02:12:59 PM »
Really!!?? Anecdotal or personal experience there koko? ... snipped ... Is this some new policy or blitz?
http://www.ducatimonsterforum.org/index.php?topic=62069.0
dmb80
« Reply #9 on: March 06, 2013, 12:07:05 AM »
thanks for the info people it worked a treat. waytogo
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Moderator
Often wrong. Never in doubt.
« Reply #10 on: March 12, 2013, 04:55:04 AM »
My previously open clutch now lives behind one of these....  Undecided
... Down side is that its not quite so striking to the eye as it was.  Plus side is that its not quite so striking to the eye as it was  Wink.
And kittens everywhere are rejoicing at this contribution to road safety   Roll Eyes laughingdp
« Reply #11 on: March 12, 2013, 04:56:56 AM »
why?
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Moderator
« Reply #12 on: March 12, 2013, 05:08:33 AM »
why?
« Reply #13 on: March 12, 2013, 05:22:57 AM »
which cover did you have before and which cover did the guy get cited for?
FIFO
Doing the latter
« Reply #14 on: March 13, 2013, 12:32:57 AM »
Hey Unge
You need to attach a wiper blade to the pressure plate to keep the window clean  Wink
Pages: [1] 2   Go Up
