February 24, 2025, 07:49:13 AM
Airbox replacement bracket - still available?
Topic: Airbox replacement bracket - still available? (Read 955 times)
Mrnoisy
March 05, 2013, 04:23:36 AM »
A thread from a couple of years ago had a bracket available to replace the Airbox ECU mount. Is this still available, or does anyone have rough dimensions so I can knock something up?
Cheers
Stormtrooper
2011 Monster 796 ABS
Re: Airbox replacement bracket - still available?
March 05, 2013, 08:41:51 AM »
I'll assume your talking about the new gen 696/796/1100 Monsters and I'll also assume your talking about the bracket that supports the ECU and battery that allows you to remove the airbox so you run pod filters? If so, that bracket was made my member "doworkson" and was a limited run thing and is consequently no longer available. One member hacked up the stock airbox only retaining the portion that held the ECU and battery in place...that's an option. Another alternative is the WASP filter kit...it comes complete with bracket, filters, etc. but is pricey.
Mrnoisy
March 06, 2013, 11:44:16 AM »
Yes you're right - I had hoped it was an ongoing source. The Wasp kit is over £1000 in UK, so I think I'll be getting my fretsaw out!
Cherrs
