mystery oil leak
Started by jerryz, March 06, 2013, 03:03:32 AM
jerryz
I have posted about this before , 750ss has a mystery oil leak on the rear cylinder , i have removed it and replaced all gaskets and O rings and it also has a new breather assembly
still leaks on rear left hand corner and about 1/2 way up the cylinder? compression is OK so cylinder cant be craked ,, now i am at a complete loss of ideas ????
zooom
did you replace the studs when you removed the rear/vertical cylinder to do the base gasket?
2010 KTM 990 SM-T
The cylinder may not be cracked into the combustion chamber, but it could be cracked/porous from an oil passage to atmosphere.
jerryz
Quote from: zooom on March 06, 2013, 08:33:30 AM
No they were all secure ,, but i am going to seal them all again
