Modest beginnings of my M750 project
Started by memper, March 07, 2013, 07:40:15 AM
memper
Perhaps. I'll see if theres a NAPA in brooklyn. And I dont have to wait which is worth a million.
Quote from: memper on March 16, 2013, 03:26:44 PM
I think the part# is H-209
Quote from: ducpainter on March 16, 2013, 08:10:20 AM
How does Ducati get away with that junk they use for the drain and o/flow hoses?
It seems to hold up ok.
The problem comes with high pressure hose that is reinforced.  The inside is ethanol resistant, but the outside is not, may not even be gasoline resistant.  The outside wrapper goes, then the textile, then tragedy.
Quote from: howie on March 16, 2013, 04:35:54 PM
If he was running a high pressure system I'd understand the issue, but he isn't.
Am I missing something?
brad black
the submersible hose is labelled SAE R10.  if it doesn't have that, its not specifically rated for use in petrol.  diesel and alcohols are different to petrol (sorry, gas).
Brad The Bike Boy
http://www.bikeboy.org
Quote from: ducpainter on March 16, 2013, 04:48:02 PM
Nope, any low pressure hose should work as long as it is ethanol/gasoline resistant.
brad black
the hoses that are single wall, generally referred to as vacuum hose, are usually petrol resistant.  most fuel hose are dual layer tho, both low and high pressure, and have an inner that is fuel resistant, a woven reinforcing layer, then the outer which is generally not fuel resistant.
the little hose ducati use in the tanks is just a single layer hose, so no worries.  the hoses they use in a 916 tank from cap recess to pump plate will be resistant.  there was a recall years ago to replace some of the hoses in some of them.  i have some r10 stuff that is really stiff, and kind of a pita.
Brad The Bike Boy
Quote from: brad black on March 16, 2013, 07:06:45 PM
The NAPA product has the correct rating
memper
memper
Whelp, Pinwall Cycles refuses to separate the pump from the fuel sensor and cap flange they are selling. Wish I had seen that before  [bang].
So if I go for aftermarket/auto parts store, any idea what pump I can use?? Any low pressure (3psi) pump will do?
If you utilize the return, pressure isn't very important as there is no stoppage of flow and no pressure build up..
That's why the high pressure efi pump would work.
You'll still have to cut a tube inside the tank to use an external pump.
The OEM setup is the best alternative to an in tank pump, IMO, as it will utilize the bracket already there.
SpikeC
 Have you checked the assortment of fuel pumps at JCK Whitless?
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
memper
Quote from: ducpainter on March 18, 2013, 11:14:20 AM
After looking into the situation more I have decided to agree with you and do an internal set up. Pinwall Cycles has an OEM ss pump with a fuel sensor and a tank flange for $35 or so. I'm guessing that I would be hard pressed to find an aftermarket that fits the mount for that price. Agree?
Quote from: memper on March 18, 2013, 04:27:56 PM
Absolutely...
and the supply of replacements if that one ever fails is almost endless.
memper
It occurd to me that it might be wise to check the sending unit. Its from '96. Do they go bad? How would I go about checking for continuity?
