Spark plug?
Started by chitown, March 11, 2013, 10:34:33 AM
chitown
So I am also replacing my spark plugs and I have searched and read almost every thread about spark plugs on this page.  I orders ca-cycle works plugs which are non resistor and are backed by Chris Kelly.  When I recieved the plugs I noticed they where the same plugs I use in my 1978 rd400 2stroke.   Now my ignition system I have on my 2 stroke have to use non resistor plugs because of the type of coils I have on thereor I will damage them.  Will I run into problems with my 09 696 with non resistor plugs.  I am not looking for performance out of them. I don't really buy the ho gains that are said to be given with the non resistor plugs.  So what do you guys think ?
chitown
come on guys help me out. resistor or non resistor.  I have till tommorro and I am just going stock.  lol   I need to start this bike. I miss the noise
if you ordered from ca-cycle you are good to go . . .
Ddan
I wouldn't use a non-resistor plug.  I did a quick search and the recommended plug is NGK DCPR8E
Ducati Monster Forum at
www.ducatimonsterforum.org
Using a non resistor plug on a street bike is not a good idea.  It can cause interference (ignition static) on radios,and TVs as you pass by, and possibly affect your bike's ECU.
Quote from: Ddan on March 12, 2013, 04:11:09 AM
Quote from: howie on March 12, 2013, 06:10:19 AM
weird, since I was unable to get the recommended plug and was able to find teh non resistor model, I did install it in my M620 and have had no issues . . .   ???
battlecry
You may have a resistor built in the spark plug cap.
Quote from: battlecry on March 12, 2013, 07:19:48 AM
I have the Evoluzione spark plug cables .. .
Ddan
It can also make your electronic flasher for LED directionals go batshit   ;D
Quote from: Darkmonster620 on March 12, 2013, 06:15:06 AM
I said can, not will.  Depends on how well the computer and wiring from some sensors are shielded.
Quote from: howie on March 12, 2013, 10:06:44 AM
howie, we all know how "weird" my particular bike is . . . .
Spck31
+1 it will cause interfence and with time ecu problem's. And there is no resistor in the 620 sparkplug cap.
Quote from: Spck31 on March 12, 2013, 10:48:05 AM
I have the Evoluzione spark plug cables .. .. ..
but, they're going out, being in the engine for one year and about 5000kms of local gas so time's out on them . . .in go Champion R4CH, I know you all prfer NGK, but, these work better, at least here
Heath
You should be running
NGK 4339 DCPR8E Nickel Spark Plug
SKU: #DCPR8E
ITEM: #NGK4339
http://ca-cycleworks.com/ngk-dcpr8e-each
OR
NGK 6546 DCPR8EIX Single Iridium Spark Plug
SKU: #DCPR8EIX
ITEM: #NGK6546
I run the Iridiums in my S2R800 and have been very happy with them.
2007 Ducati Monster S4RT
Quote from: Heath on March 12, 2013, 11:41:30 AM
SKU: #DCPR8E
ITEM: #NGK4339
OR
SKU: #DCPR8EIX
ITEM: #NGK6546
I've used both . . . somehow my Gina likes the Champions better ???
