February 24, 2025, 08:20:19 AM *
Author Topic: '00 M750 Mikuni rebuild  (Read 1035 times)
bdfinally
« on: March 13, 2013, 05:08:00 PM »
It's springish here and I've decided it's time to think about a carb rebuild. 34,000 miles and they haven't been apart since a Stage II kit went in with about 3,500 on the clock. What's the easiest way to go about this, just buy another Stage II kit, plus jet o-rings and bowl gaskets? As always thanks in advance
« Reply #1 on: March 13, 2013, 06:19:25 PM »
I've been very satisfied with the Factory Pro kit, including some of their nickel-plated emulsion tubes.
You can go for the main jet o-rings, carb bowl 'gasket', jet body gasket, mixture screw o-rings, float valve o-rings, from Ducati.
Don't leave the diaphragms out of the carbs for very long, they can shrink and are then a beyotch to fit back.
If you're feeling ambitious, you can split the rack and clean the 'anti-backfire' diaphragms and pistons.
Fair warning, it's a hassle to get the balance spring back in.
If you're going to split it, get a pair of o-rings for the vent tee and seal rings for the fuel inlet tee.
Don't lose the little filter on the fuel inlet.
You could get a new one of those for fun.
blocbul
« Reply #2 on: March 14, 2013, 05:31:23 AM »
As said before, be sure to change the emulsion tubes. They wear fast (even if you can't really see any visible wear) and it affects mileage and drivability at low speeds.
