Old bike neutral switch, new harness.. (paging Brad Black)
Started by stopintime, April 21, 2013, 09:56:53 AM
So, my S2R800 got new old 750 cases with a different switch at the back of the cases.
What's the difference? Can they be modified to work with each other?
(Because it's not connected at the moment I have all sorts of issues: no green light, no start without pulling clutch and raising side stand)
I think the old (750 type) switch was single wire and the new (800) is a two wire switch.
I'm not certain, but you should be able to connect the power wire to the switch, and the ground to the chassis.
That's what I'd try.
Suggestions about how to establish which of the two harness wires I choose to connect the single positive 750 wire to? Try both and see which works? (I own a multimeter, but we're still strangers)
Quote from: stopintime on April 21, 2013, 10:31:35 AM
Set your multi meter to 12V and turn on the key. The wire that registers voltage would connect to the switch.
Not so fast  :P
One red probe from the meter to the two-pin harness connector?
The other, black, from the meter to where?
The bike sends constant positive, through the plus/single wire, to the switch?
Switch breaks that positive to activate the green light?
As easy to hold a wire between the single wire and check which of the two harness connector pins make the light go green? Short circuit danger?
Quote from: stopintime on April 21, 2013, 11:15:55 AM
Not so fast  :P
Sorry...
Red probe to the wire harness and the black to a chassis ground.
Switch makes the ground connection to complete the circuit. In this circuit the bulb prevents it form being a 'short circuit'.
The advantage to using the meter is it removes the possibility of short circuits and damage.
So, with the bike in neutral, ignition on, I find the pin that makes the meter show a reading (the other pin won't show a reading) The wire going to that 'live' pin connects to the switch - the other to engine/chassis ground. Correct?
Will the green light be activated through the testing procedure?
Quote from: stopintime on April 21, 2013, 01:07:52 PM
Correct...
unless the smoke gets out. ;D
Gimpy
 [bang]  other way around - my 750 engine is the one with a dual wire switch and connector - my 800 harness has a single wire bullet connector.
Not sure, but you should be able to use the switch from your 800.  I think the difference is the newer one grounds internaly to the case so a ground wire is not needed.
Quote from: howie on April 22, 2013, 03:50:06 PM
Don't know how it looks inside, but the hole for the 800 switch is deep (before you get to the threads) where the 750 is not. Either the case thicknesses are very different or the switches are.
Confuses me a little more - the parts catalogs for M750i, S2R800 and SS750 all show the same switch (two wires)
The switch does need to be the correct length to work, which one would be the correct length for your now custom operation I don't know.  As I remember Ducati went to the single wire switch around 2001.  Too long can be spaced to work.
Another "don't know" - this donor engine had a 5 speed gear box, but now houses my 6 speed....
If the switch is two wire then just ground one of the wires and feed voltage from your harness to the other and see.
The smoke shouldn't escape.
