January 18, 2025, 02:54:43 PM
Customizing vertical dual headlights
Topic: Customizing vertical dual headlights (Read 7131 times)
awax1969
Re: Customizing vertical dual headlights
Reply #15 on:
May 10, 2013, 03:29:35 AM »
@Stormtrooper .. people like you make life easier. Thanks man...
I will receive my bike mid jun and by then I will sure would have bought the stuff by then and start on this project. One question...: do you think i should just forget about the blinkers? They are attached to the main original headlights...
Guys once I am dont I will sure share the photos with you
Stormtrooper
2011 Monster 796 ABS
Reply #16 on:
May 10, 2013, 07:34:51 AM »
Quote from: awax1969 on May 10, 2013, 03:29:35 AM
Glad I can help! I would love to see this stacked setup on your 796. Ditch that damn smashed cartoon headlight! Regarding the blinkers; yes you need those. Here are a few clean options:
Oberon bar end LEDs (I run these and love 'em!)
MBW fork wrap around LEDs
Joker Machine LEDs
sullytl71
Reply #17 on:
May 10, 2013, 10:15:13 AM »
Stormtrooper, I love this concept! I have been debating doing the Rigid Dually like you did, or the stacked like awax is looking to do. I got in touch with Crime Scene Choppers and they said they're having some of the brackets you had made crinkle black powder coated so I may order one and start with that idea. Nice work man!
A father and son are talking one day....
What do you want to be when you grow up son?
A fireman Daddy!
Sorry kid, you can only do one or the other.... Grow up, or be a fireman!
Stormtrooper
Reply #18 on:
May 10, 2013, 10:22:51 AM »
Quote from: sullytl71 on May 10, 2013, 10:15:13 AM
Nice. Rigid recently introduced this model, the SR-Q2. If I were to do it again I would use this one instead of the D2.
sullytl71
Reply #19 on:
May 10, 2013, 10:24:18 AM »
Do you think that would fit that same custom bracket you had made? Or would it have to be stacked vertically?
A fireman Daddy!
awax1969
Reply #20 on:
May 10, 2013, 10:29:47 AM »
The Brackets above "the two fork clamp mounts" which @Stormtrooper posted seems to be great BUT:
what is the size of the clamps relative to the center of the two forks. I am a little bit worried that the vertical headlights would be off centered ...
anybody knows what the is the exact measurement of the space between the two forks?
The forks as I heard are 43mm
sullytl71
Reply #21 on:
May 10, 2013, 10:44:33 AM »
Quote from: Stormtrooper on May 10, 2013, 10:22:51 AM
Also, I may have been reading it wrong, but does this SR-Q2 throw 1568 lumens compared to the 2600 with the Dually 2? Doesn't that mean you'd be getting less light? Forgive me if I'm wrong (and I usually tend to be), just thought I'd ask.
A fireman Daddy!
Stormtrooper
Reply #22 on:
May 10, 2013, 11:23:42 AM »
Quote from: awax1969 on May 10, 2013, 10:29:47 AM
The distance between the forks is about 6.5" if I recall. For alignment; you would just rotate the fork clamps on the fork axis in order to get the headlight vertically aligned...easy peezy. Forks are 50mm O.D.
Quote from: sullytl71 on May 10, 2013, 10:44:33 AM
The SR-Q2 throws 3030 lumens...more powerfull than my D2 at 2600 lumens. And YES it would fit the Crimescene mount as-is! The width of the SR-Q2 is 5" which would fit nicely between the forks. This would look better than my square D2 IMO.
Last Edit: May 10, 2013, 11:25:57 AM by Stormtrooper
sullytl71
Reply #23 on:
May 10, 2013, 12:48:50 PM »
Quote from: Stormtrooper on May 10, 2013, 11:23:42 AM
Thanks man! Yea, looks like I may have to go with that one then.
Edit: Just ordered one in black from Amazon. Whenever I can get the bracket from Crime Scene I'll be reaching out to you Stormtrooper for some help and hints with the install. Thanks for the great idea!
Last Edit: May 10, 2013, 12:57:16 PM by sullytl71
A fireman Daddy!
awax1969
Reply #24 on:
May 10, 2013, 01:13:48 PM »
@Stormtrooper
Respect man
irridium
Reply #25 on:
May 22, 2013, 12:21:38 AM »
that setup will look killer! look forward to finished pics
Reply #26 on:
May 22, 2013, 06:58:01 AM »
Forks are 50mm at top triple 54 at lower triple so depends where your mount clamps as to sizing
