LOUDEST CANS that are not straight pipes
Started by showerfan, May 10, 2013, 11:16:33 AM
Spy+
SF 848
M696
Can am spyder gsr
DexterMorgan
-Adam-
2013 Monster 1100 Evo
2013 Monster 796 (wife's)
memper
Yes, straight pipes sound nasty. But its kinda sharp. HD straights sound different than our bikes. More "rounded", less sharp.
You can cut and core your stock cans. Shorter will be louder. However with less airflow resistance from reducced or lack of packing the air velocity will be messed up. Same goes for straight pipes but worse. Trust me, i did lots of experimenting trying to get a decent street performance out of straight pipes.
Low end torque will suffer but top end *may* improve. But i doubt you spend much time at WOT.
It may seem like a power boost bc it sounds meaner and you will be throttle giddy. But power is less.
Most HD guys running drag pipes dont realize how much more hp could be had with a good exhaust.
That said i am running DM conicals and they are loud but not obnoxious.
memper
Here is a great vid by S&S about exhaust tuning. Its about HD's but all the theories apply across the board, IMO.
rgramjet
I had stainless Forrza low pipes.  They were relieved of the fiberglass inside.  The sound was wicked.......not in a boomy sort of way, more like top fuel dragster.
I missed the Bass which is why I switched to Fresco conical highs.
-Sofadriver
Kopfjager
Quote from: memper on May 11, 2013, 07:31:58 AM
[thumbsup]
Kopfjager
memper
#22
Quote from: kopfjäger on May 11, 2013, 09:02:38 PM
Melvin's 800 with Termis.
Wow!
FWIW, I have a set of lollipop baffles in the mid-pipes just after the end of the headers. I do notice a difference. If i could afford a *real* set of pipes I probably wouldnt need them. Mine are a bolt with a washer welded on top
showerfan
melvin's bike makes me too jealous -- i can't watch that again. why didn't i buy an orange s2r  [bang]
Give me a shout if you know any good motorcycle detailers in the Westchester area.
Autostrada Pilot
Quote from: Duck-Stew on May 10, 2013, 12:20:39 PM
Ducati Performance 'Conti-replica' megaphones.
Either are borderline ear-bleeders.
Like the ones that are on BP's Tostapane?
2003 Monster 620 Dark - Sold
1999 Monster 900 City - Sold
i have a pair of conti style megaphone.. ebay specials
those with straight 2 into 2 with no crossover... was so loud had to put baffles to get down to 97 db. on a 696!
Not really helpful, as I believe he's out of business - but ARC Fabrication - Doug Cook set of megaphones on an S2R1000 were rather ear shattering.
showerfan
FWIW i toyed with the idea of some DANMOTO GP-style cones... but being concerned about the made-in-chinaness and the customer service, etc., i am going instead with some MIVV titanium ovals.
they may not be earth-shattering, but i believe they will be loud, sans baffles, and provide decent back-pressure...
cheers [beer]
Randy@StradaFab
So what do you guys think of these end caps? Machined from billet aluminum, they will bolt to Titanium cones. Bolt pattern is the same so you could change the look if you wanted. Ti cones are 13" long, 2in" OD on the small end and 4" OD on the large end. I could also do a full Ti reverse meg. They will be loud ;D
theprocess
Quote from: showerfan on May 10, 2013, 01:24:16 PM
CHOP IT YOURSELF! i may actually do that -- i want to go for more of a mad-max kind of look, after seeing/hearing what jamie robinson did to his cbr on ``RIDE APART''
Digging the hooligan-flat tracker style. Roland Sands (RSD) makes some killer bikes.
Same bike: https://www.youtube.com/watch?feature=player_detailpage&list=UUdl-mzSkTtqAqed7CRNcD5Q&v=K44tgOLn40A
Desmo tracker: Riding Roland Sands Design's Desmosedici Street Tracker
