February 21, 2025, 02:40:17 PM
Rear brake caliper rebuild: replace seal on 2003 620
Topic: Rear brake caliper rebuild: replace seal on 2003 620 (Read 2002 times)
808Ducati
May 12, 2013, 12:36:54 PM »
Rear brake locking up, took apart the caliper to clean it up but the pistons are not moving freely. I want to rebuild the caliper but I cannot find where to purchase the seals; anyone know? Or do people just pop out the pistons and clean everything up without replacing the seals? Or buy a new caliper? Thanks
SpikeC
Spike in PDX
Re: Rear brake caliper rebuild: replace seal on 2003 620
May 12, 2013, 01:23:13 PM »
I think that the usual approach is to replace the caliper as the consequences of failure are rather dire. It is an easy enough job if you can find the parts, butt with liability being what it is these days, whatcha' gonna do?
edit: looking at google, there appear to be many kits available!
Last Edit: May 12, 2013, 01:26:42 PM by SpikeC
Spike Cornelius
PDX
2008 Bimota DB5R woo-Hoo!
1965 T100SC
SpikeC
Spike in PDX
May 12, 2013, 01:29:10 PM »
http://compare.ebay.com/like/330901075324?var=lv<yp=AllFixedPriceItemTypes&var=sbar
Spike Cornelius
PDX
1965 T100SC
seevtsaab
05 M620
June 14, 2013, 06:01:38 PM »
Any update?
I just discovered one of my pistons stuck, rear caliper 05 620.
suzyj
Does my bum look big on this?
June 14, 2013, 09:36:36 PM »
Rear calipers are really cheap.
http://www.yoyodyneti.com/Category.aspx?CategoryID=3002
Get a gold one to match goldline front calipers.
seevtsaab
05 M620
June 15, 2013, 02:21:11 AM »
Thanks Suzyj, I ended up ordering used from a popular auction site plus pads. Kinda need the assured quick delivery as much as anything, leaving in 10 days for about 4K mile trip.
Goldline front calipers - you are funny, I see what you did there.
seevtsaab
05 M620
June 20, 2013, 10:15:12 AM »
minor update - received used caliper $65 shipped (gold), looks pristine. Pads I ordered didn't arrive yet (that's bad!)
Used Caliper came with pads installed (that's good!).
My little power bleeder thingy failed (won't suck - that's bad).
Rear brake just as easy to bleed without pump (that's good).
I did get the stuck piston on my old caliper to pop back in, I'll double check to see if it still leaks, when I get around to it.
