January 07, 2025, 10:52:49 PM *
Author Topic: Do Pirelli tires have a wear strip?  (Read 2181 times)
ejw24
'06 M620 - The Radical Red Racer #2
« on: July 03, 2008, 06:00:50 PM »
Cleaning the chain tonight I noticed a spot in the center of the tire where some white is starting to come through.  Please tell me it's a wear strip and not the cords!
Taking the bike in next Friday for it's 6k service so I will get a new tire but I have a 150+ mile ride to the dealer. Thanks!
I'm having a failure to thrive...
Omnipotent Potentate
Personal Pretext
« Reply #1 on: July 03, 2008, 06:08:02 PM »
White = Chords
They do have wear indicators... which you've probably obliterated.  Get thee a new tire
j.davis
« Reply #2 on: July 03, 2008, 07:12:10 PM »
Here are two different areas of the Pirelli on the rear of my VFR after I got home from my last ride.  If they look like your tire, you probably are looking at cords.
jD
« Last Edit: July 04, 2008, 07:11:26 AM by j.davis » Logged
ejw24
« Reply #3 on: July 03, 2008, 07:22:46 PM »
Here are two different areas of the Pirelli on the rear of my VFR after I got home from my last ride.  If they look like your tire, you probably are looking at chords.
jD
That's what I got showing, hope I can make it to Denver.
Thanks for the help guys!!
« Reply #4 on: July 03, 2008, 08:07:56 PM »
Take it by truck, trailer, van...... begged, borrowed, rented, stolen.....whatever..... please don't ride 150 miles on a tire with cords showing.
ejw24
« Reply #5 on: July 03, 2008, 08:24:32 PM »
That's what I'm thinking, while the tire doesn't look nearly as bad as the one in the picture I don't want to chance it.
Ducatista
I don't need to brag about a titanium member.
« Reply #6 on: July 04, 2008, 06:44:37 PM »
Is there any shop at all local that can mount fresh rubber for you if the wheel is off the bike?  That would be better than a crash from a flat.   Embarrassed
carbon fiber Superbike front fender, bar end mirrors, floating cast iron rotors, carbon fiber chin fairing, Cycle Cat frame sliders, Arrow carbon fiber low mount slip ons, Rizoma billet cam belt covers w/ plexi windows, Rizoma billet front sprocket cover, billet handlebar clamp, carbon fiber rear hugger, tail chop, open air box, Corbin seat, stainless clutch springs w/ black keepers, suicideless sidestand bolt, Evoluzione clutch slave cylinder
www.myspace.com/bitgoddess
ScottRNelson
Mr. Dual Sport Rider
« Reply #7 on: July 05, 2008, 08:48:53 AM »
You're taking a big chance riding a motorcycle 150 miles with cords already showing.  If it fails, it's not going to lose air slowly, and if it fails when you're riding at pretty high speed you might not be able to maintain control before you can get the bike stopped.  So even if you don't crash, you'll still have to haul it the rest of the way in a truck, but it will be more expensive for you than if you were to haul it in a truck in the first place.
If it were me, I would put a new tire on first, using a local motorcycle shop to put the tire on the rim, then ride it for the service.
ejw24
« Reply #8 on: July 05, 2008, 08:27:54 PM »
Thanks for the advice, I'm going to trailer it to Denver.  A new tire at a local shop isn't an option.....Aspen is limited for any motorcycle services.
EEL
« Reply #9 on: July 06, 2008, 07:02:38 AM »
Every pirelli I have ever owned matches the picture that was posted earlier. after the 3rd tire, I switched to Michelin.
CMDRDAVE
'01 Yellow M900i.e. '98 Yellow 748
« Reply #10 on: July 06, 2008, 10:05:18 AM »
With out a wear strip, what should be used for a "tripwire" for tire replacement?  My Diablo's look good so far I just want to be carefull.
Insert witty comment here-->
« Reply #11 on: July 06, 2008, 12:25:06 PM »
Diablos have wear bars, I think all tires have to have them, by law.
They are noted, I believe by little pitchforks at the edge of the tread surface.
ScottRNelson
« Reply #12 on: July 06, 2008, 04:23:05 PM »
Wear bars look like the circled part of this tire.  You should have something similar on the Diablos.
« Reply #13 on: July 07, 2008, 11:34:52 AM »
Edit, there is little 'TWI' lettering right at the edge, and there's a shallow bar in one of the tread grooves, about an inch off of centerline.
CMDRDAVE
« Reply #14 on: July 07, 2008, 06:56:15 PM »
Ah Ha! but my TWI is right next to a "pitchfork"  laughingdp
