Hydraulic systems air bleeding techniques.
Started by kokis, May 17, 2013, 10:46:02 AM
kokis
On youtube I learned that in order to remove air from brake\clutch system you have to pump out at least 3 full fluid tanks while checking if any air bubles comes out from system to transparent tube.
But my mechaniq guy said that it is not necessary. His tehnique is pull lever 5 times and hold, open bleeder while holding. 4-5 times and you are done. My brake works fine after that procedure, but I am still skeptic.
How to clean system from air [roll] properly?
I am not pro in tech questions, but as any rider have some experience that I can share without claiming to absolute truth. Please use my advices responsibly.
LowThudd
There is no certainty. Every bike with air in the lines will be different. If there is a lot of air and/or the lines have grunge in them, it may need to be flushed with more than a bottle of fluid. Really, as long as no more air is present in the bleed line, your done. Doesn't hurt to flush the system and put in new fluid though.
memper
Agreed. There is no set number of pumps or amount of fluid one might use. You keep going until theres no more air showing.
I like to do mine then close everything up as it should be and let it sit over night. The few hours til the next day will allow any air bubbles to collect and I check by bleeding again.
MotoPsycho
Find a new mechanic.
Get a MityVac and do it yourself. Much cheaper in the long run.
SpikeC
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
memper
As bleeding is one of the set of "easy" maintenance tasks, no one should be having to go to a mechanic for it. A small crescent wrench, some clear tubing, a hose clamp, and an empty pasta sauce jar. (And some time)
LowThudd
memper
