Home Depot (or Lowes) battle royale
Started by Slide Panda, May 17, 2013, 12:29:32 PM
- Shamelessly stolen from another board- wher it was probably already stolen.
You are chosen to compete against 9 other people, a battle to the death. All ten of you are locked in your neighborhood Home Depot or Lowes (Big Box home improvement). The place is closed and lit by flood lights above exits and other misc. lights that make action movies look sweet. The goal is to kill all your rivals and be last man standing.
You are allowed to choose 3 pieces of equipment to aid you. Anything with a bar-code/SKU counts as one piece of equipment. For example, if you choose a nail gun, then a container of nails will be needed, so that would equal two pieces of equipment. You can only use the weapons you choose originally. No area of the home depot is off limits. The outside gardening area is in play, the only sealed doors are the exterior ones. Items like store owned forklifts are off limits for use - see note about bar-code/SKU.
What three items would you choose and what would be your strategy?
zooom
are you allowed to use the "off limits" equipment for mobility?
ie:can I use the mobile stairways or the forklift or cherry picker to get up onto the tops of some of the fixtures?
2010 KTM 990 SM-T
Non powered items can be used for mobility only. Powered items like lifts may not be powered on.
LowThudd
One pallette of bricks(for shelter and projectiles), a water balloon launching sling(yes, they have them there) and firemans axe. [evil]
zooom
hmmm....part of me was thinking threaded rod thrown like a javelin from up high...but that may not work so well due to limitations....
oooo...once you kill a competitor...whatever 3 items THEY have can now be yours as well though right?...Hmmmm
2010 KTM 990 SM-T
derby
Quote from: zooom on May 17, 2013, 01:02:52 PM
Quote from: Slide Panda on May 17, 2013, 12:29:32 PM
-- derby
'07 Suz GSX-R750
I would wait them all out near the candy rack at the register.
They would all die of starvation wandering the aisles looking for what they want. (same as when the store is open and there is no knowledgeable staff around to assist you)
LowThudd
Quote from: bobspapa on May 17, 2013, 03:50:41 PM
But you would only be allowed to eat three UPC labeled items. I got enough of a spare tire to wait you and your candies out. lol
M&m n snickers won't stop a framing hammer to the head.
Container of any highly flammable liquid that I see first
Torch
a book about gardening
I'd set the place on fire spreading the liquid mainly at the exit to the garden center to block escape by the others
Then I'd sit outside in the garden center and read my book while they die
Drain cleaner (lye), pump
Sprayer and a tyvek suit.
Big jugs of bleach and ammonia. And a respirator
I expect more creativity from you all
Quote from: Slide Panda on May 17, 2013, 05:05:29 PM
I'm feeling lazy and just want to read a nice book next to a roaring fire
Johnny OrganDonor
#12
I'm thinking that a pressure washer, a case of acetone, and a lighter could make a dandy flame thrower.  If I could use my own lighter, my third item would be a value pack of circular saw blades that I think would make excellent ninja throwing stars.
edit:  On second thought, I'd go to the service counter and exchange the ninja saw blades for a chainsaw chain - better for close combat.
LowThudd
No power outlets to plug the washer in. Might do better with a kerosene powered and spraying washer.
WarrenJ
