February 24, 2025, 03:52:13 PM *
News: Please Help
Author Topic: Exhaust - right heel - S2R 800  (Read 1016 times)
dang
« on: May 27, 2013, 01:01:52 PM »
Hi all-
When the ball of my foot is on the pegs (stock rearsets) and my knees pressed into the tank my right heel presses up against the heat shield on the exhaust down tubes. I would like more room on the right side, so the question is: what exhaust (down tubes/mid pipe) set up will either tuck in tighter than stock or be moved rearward? I am still debating an under the tail or shotgun style system - I am open minded about either of those, and if one will give me more room I will go that route. I don't want the boomtube/Ebox set up, but I understand that will fix my issue. Am I going to have to have the downtubes custom bent? Any and all advice welcome! Thanks.
Dan
2007 S2R 800 and a smile every time I ride...
muskrat
« Reply #1 on: May 29, 2013, 08:32:07 PM »
you are not in luck - a custom bend is exactly the only thing that will work unless you go with a boom tube or x box exhaust.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
corey
'06 Tang/Black S2R800
« Reply #2 on: June 07, 2013, 12:50:41 PM »
My Sidis have a nice melty patch from my zards before i put a guard on them. Just life i guess.
uclabiker06
"The time you enjoy wasting isn't wasted"
« Reply #3 on: June 07, 2013, 01:35:27 PM »
I just put some hi temp sealant on the part of my boot that rubbed up against my Zards and its worked out for me.  Life is what you make of it I guess
2006 S2R
2009 Smart
