Survival kit
Started by IZ, May 28, 2013, 09:17:56 AM
Quote from: IZ on May 28, 2013, 09:29:44 PM
Was looking at these at REI.  Will pick one up for my dual-sport survival kit.   [thumbsup]
One hand tourniquet too
http://www.officersurvival.org/collections/cat-tourniquet-supplies/products/combat-application-tourniquet
Created by a Navy Corpsman...
rgramjet
Don't forget the Tussin!  Put that Shit on everything!
-Sofadriver
WarrenJ
Those trauma shears Headhunter mentioned are super.  Countycom makes a downsized pair of them that is still excellent if space is a consideration, but their fullsize ones are awesome.
ZLTFUL
Quote from: sno_duc on May 28, 2013, 06:33:46 PM
"Mosting the most" means "missing the most", kinda like your photography his typing requires using your imagination to fill in the IZ_ spots.  ;)
Must to reiterate.
;D [cheeky]
2012 Panigale 1199
2003 KTM 640 Adventure
zooom
we are missing one of the most useful things that no has mentioned yet....
zipties !!!
2010 KTM 990 SM-T
Quote from: zooom on May 29, 2013, 10:06:57 AM
zipties !!!
Yes!
Always had those in each of my Ducs.  Learned the hard way after doing tail chop and relocating plate.  Crunched it 2 x's.  Couple of zip ties work nicely to hold the plate on until you get home.  Had to attach it to backpack the second time.
cokey
I WIN
About the goat...
Wrekz
Not sure how familiar you are with the use of all of the survival gear, but knowledge is more important than the gear. The handbooks are really helpful, but trying to read up on how to use (insert gear here) in the moment isn't ideal.
Be familiar with everything you carry prior to needing it.
WarrenJ
Quote from: Wrekz on May 29, 2013, 09:29:47 PM
Best Advice Here!
[thumbsup]
Right!
sno_duc
I agree.
However when dealing with plants, I'd like to have the reference book (survial manual) in hand.
The time to find out that a particular plant or berry is poisonous is before you wolf down a big handful.
2 lbs of food even dehy will last a couple of days, a 2lb survial manual will allow you to safely eat local flora for weeks.
A conclusion is the place you got tired of thinking
Wrekz
Good call.  I'm pretty confident with the gear that I carry, but without a field guide, my plant identification is a little lacking.
muskrat
is this survival kit dual purpose?  If the Zombie apocalypse happens you're screwed so carry some ammo.... [evil]
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Does that fit in the water proof bag provided?!
Quote from: IZ on May 30, 2013, 12:27:39 PM
Ziplock....
