January 09, 2025, 07:57:37 PM *
Author Topic: 2002 M750ie tach issue  (Read 746 times)
KIKH400
« on: May 28, 2013, 09:07:17 AM »
My tach just started this the other day--
The tach needle starts in about the 5 o'clock position, and sweeps up when you turn the key.  The sweep is about the same distance as when it worked right. It sweeps up, then returns to the 5 o'clock position.  When I start and run the bike, the tach movement seems about the same as it did, except that it starts at about 5 o'clock, where it used to start at about 8 o'clock (700 rpm or so).  The bike runs fine.  It seems like the tach needle just slipped, and is now just oriented wrong.
Any advice?
« Reply #1 on: May 28, 2013, 11:45:51 AM »
Most likely the needle has just slipped on the shaft.
Problem is, the only way to open a 2002 cluster is cutting.
IIRC, someone has done a FAQ or how-to post here somewhere....
Check your cluster, it *may* be a later model that can be opened.
KIKH400
« Reply #2 on: June 04, 2013, 02:01:37 PM »
Thanks. I'll take the face off when I can. For now, just riding
cmejia1978
« Reply #3 on: June 05, 2013, 08:07:06 AM »
no, no nooooo; I did it and no cutting at all, here are some pics to help you:
http://www.flickr.com/photos/80492390@N05/sets/72157631906503470/
The tricky part is how to tack the back little pins that hold the needles.. patience LOTS of it...
http://www.flickr.com/photos/80492390@N05/sets/72157633404066625/
 coffee
KIKH400
« Reply #4 on: June 11, 2013, 10:17:54 AM »
Thanks.  I've been riding when I have the time rather than fixing.  At this point, its bothering me less and less and it may have to wait until cold weather.
