February 24, 2025, 03:23:55 PM *
Author Topic: Longer kickstand options for S2R?  (Read 1819 times)
eyduc
« on: May 30, 2013, 07:29:19 AM »
I raised the back end to the max on my S2R1K with the stock link.  Now, it leans a bit too much for my comfort.  I use a hockey puck whenever I park it.  I haven't seen any discussion on this topic recently.  So, what are my options?   Aftermarket, other Ducs, etc.?  I only need an extra inch or so on length.   One option I may do is have a fabricator/welder just add some length of aluminum and a pad.
ChrisK
« Reply #1 on: May 30, 2013, 09:56:52 AM »
I don't have a clue what the lengths are or if they'd even swap buttt.... on my 98 M900 I'm wanting a shorter kickstand. If the kickstands are direct swaps, and yours is shorter than mine, I'd propose a trade? I won't be able to measure till tonight.
Anybody know how the two compare off the top of their head?
1998 M900
2007 CBR600RR Track Bike
1980 Lambretta Moped
Supra Boats enthusiast
ChrisK
« Reply #2 on: May 30, 2013, 10:00:47 AM »
Or if just the leg can be swapped, while leaving the brackets...
1998 M900
S2R 800 '07
« Reply #3 on: May 30, 2013, 10:23:38 AM »
SSR SlingShotRacing one inch longer  waytogo
http://www.monsterparts.com/pc/SSRBKS/Accessories/SSRBKS.html
Their black has been reported to fade or turn to another color.
Maybe they started to use another method, but I doubt it and got mine in silver/natural.
eyduc
« Reply #4 on: May 30, 2013, 10:29:29 AM »
stopintime:  Thanks for that info.  I'm hoping for a lower cost option from the Ducati parts bin, as in a used one.  It looks nice, though!
ChrisK:  I'll keep you in mind if we find that it swaps and yours is longer.
cayman s
« Reply #5 on: May 30, 2013, 05:22:02 PM »
Not even close.
scaramanga
« Reply #6 on: June 05, 2013, 02:58:01 PM »
I would love to see a photo of your s2r with the back end jacked.
I would also like to know how it handles with the mod, i'm thinking of doing the same.
2008 s2r1000
2011 sf1098
eyduc
« Reply #7 on: June 05, 2013, 07:21:58 PM »
It's about 10mm down in front and 20mm up in rear.  I'm 5-6 and tip-toe the bike at the lights.   Before I raised it, it was all the way down (as delivered) and I could almost flat-foot it.   I firmed up the suspension at the same time since it felt a bit soft on the bumps.   I mostly commute on it and there isn't many roads here that challenge the handling in corners.  It feels overall much improved in the way I ride.    I'm just an average rider.   So, I can't really push it beyond it's limits anyway.
You can see in the pics that the bottom of my Termis just clear the top of the tire when looking straight from the side.
scaramanga
« Reply #8 on: June 06, 2013, 11:06:40 AM »
very nice, cheers
2008 s2r1000
2011 sf1098
uclabiker06
"The time you enjoy wasting isn't wasted"
« Reply #9 on: June 06, 2013, 09:50:08 PM »
The higher you raise the rear, relative to the front, the less stable the bike is. if you use it primarily for commuting then I would say the front and back should be the same.  Raising the rear makes the bike more agile or flickable but you have to have an amount of skill that most alot of us don't have to make use of that extra agility.
Why don't you just lower the rear to match the front & solve your tip toe/short kickstand problem w/ one stone?
« Last Edit: June 06, 2013, 10:26:53 PM by uclabiker06 » Logged
2006 S2R
2009 Smart
eyduc
« Reply #10 on: June 07, 2013, 02:12:25 AM »
The main reason I raised it was to sharpen the handling and a little for cosmetic reasons (I like back high look).  I was already thinking to put it back to where it was but with the firmer settings. I figured someone would chime in on the negative side of it.   I have three roundabouts on my route and a few tight corners in my neighborhood.   With the raised rear, I now find that I go slower in the tight stuff.  I wasn't sure why.  I thought it was just my slight fear of crash #4.   There's a slight feeling I was hitting my lean limit so to speak.  I didn't think it was from the raised rear.  I thought that regardless of the riders height and if the bike was adjusted within its factory limits, it should handle ok and at least better.  Also, I know that raising the rear decreases the rake angle and makes the steering faster.  Now, I understand the instability that goes with it.
I'll probably lower it this weekend.  It's not a quick job since the exhaust practically has to drop in order to access the rod.  I do feel more control on any bike when I can flat foot it.  My Hawk GT was the one other low enough for me.  Thanks for explaining it.
uclabiker06
« Reply #11 on: June 07, 2013, 01:33:44 PM »
You got it.  I haven't gotten to the rod in a while so I don't remember if you have to remove the exhaust or not.  Good luck & ride safe..
2006 S2R
2009 Smart
