November 30, 2024, 09:02:42 PM *
Author Topic: Under the seat heat?  (Read 2298 times)
Skybarney
Fako
« on: May 30, 2013, 07:49:31 AM »
So after a few rides here in the heat of California I realized I need to do something to fix what can only be described as "Burning bum" I have decided to try a couple of things to fix it.
1: Saddlemen seat with the split.  Figure it it ain't touching the bum it can't be burnt.
2: Line the bottom of the new seat with this stuff; Thermo-Tec 13575 12" X 24" Adhesive Backed Heat shield.
Has anyone here used this stuff under their seat before?
SpikeC
Spike in PDX
« Reply #1 on: May 30, 2013, 10:02:12 AM »
 Haven't used it butt sounds like a good idea to me!
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
memper
« Reply #2 on: May 30, 2013, 10:42:58 AM »
Or maybe a thin sheet of aluminum?
cayman s
« Reply #3 on: May 30, 2013, 12:51:20 PM »
Used something similar on my 999's saddle.  There wasn't that much difference that I could tell.
Used this stuff on the underside of my Aprilia's gas tank:
http://www.amazon.com/DEI-010392-Reflect-A-GOLD-12-Sheet/dp/B0039Z5TRC/ref=pd_sim_auto_3
« Last Edit: May 30, 2013, 12:55:53 PM by cayman s » Logged
SpikeC
Spike in PDX
« Reply #4 on: May 30, 2013, 01:06:08 PM »
 Just having a reflective surface isn't enough, you need some dead air space as well. There are sheets of metalized stuff with bubbled that would work best. I have not looked them up butt have seen the stuff used in AirStream trailer walls.
Spike Cornelius
  PDX
   1965 T100SC
uclabiker06
"The time you enjoy wasting isn't wasted"
« Reply #5 on: May 30, 2013, 01:19:57 PM »
How about relocating the voltage regulator maybe
2006 S2R
2009 Smart
Skybarney
Fako
« Reply #6 on: May 30, 2013, 03:03:38 PM »
I sthe vo9ltage regulator right under the seat on a 2013 Evo?  Anything that would help needs to be done.  At times it is like all of a sudden a red hot poker goes straight up my bum............  so bad gotta stand up!
memper
« Reply #7 on: May 30, 2013, 03:09:50 PM »
Wu-Tang style...
« Reply #8 on: May 30, 2013, 10:15:45 PM »
it's the rear header on the Evo.
best way is the create another heat barrier, between the bottom of the subframe/tank and the header
putting it on the seat itself will just absorb the heat onto the material and transfer it to the seat.
you need air like mentioned before, between the shield and the seat
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #9 on: May 31, 2013, 12:02:30 AM »
Pretty sure the its under the rhs oil cooler shroud, so nothing to be gained there.
I hated the arse-frying on my M696, I found ceramic coating the exhaust helped.
Stormtrooper
2011 Monster 796 ABS
« Reply #10 on: June 01, 2013, 08:27:52 PM »
This is the first heat complaint I've seen on the Evo with the low mount exhaust. I have had no complaints with my exhaust with its similar design. Heat wrapping or ceramic coating the header will most certainly help. And the volt reg is no longer under the tail, that's the old gen Monsters.
Narflar
Beware the wrath of my
Professional Lurker
« Reply #11 on: June 02, 2013, 04:29:35 AM »
Only issue with heat on the EVO i've had is on my left leg.  Which is where the header crosses forward by my leg.  But under the ass heat?  I can't say I've had that but I haven't ridden in 100+ weather either.
2012 Ducati Monster 1100 Evo
2008 Honda ST1300
2008 Triumph Speedmaster
2004 Ducati M1000
BoDiddley
S4Rs In Michigan
« Reply #12 on: June 02, 2013, 03:10:58 PM »
Try the hardware store for 1\8" vent pipe insulation, foil on both sides with are pockets in between,  Cheap to.
"But sire what are we to do.  You have taken all our weapons and now the heathen hordes are at the gate.  Are we to lie down and give them our lives.  Without weapons they will make us eat ourselves."
uclabiker06
« Reply #13 on: June 02, 2013, 04:32:00 PM »
Ma bad, thought we were talking about a Monster  waytogo
2006 S2R
2009 Smart
Skybarney
Fako
« Reply #14 on: June 03, 2013, 06:43:15 AM »
Bo that is a great idea!  I have though about using that stuff to insulate my metal out building.  I think I am going to try it out!
