January 23, 2025, 04:56:58 AM *
Pages: 1 [2]   Go Down
Author Topic: Voltage regulator relocation  (Read 9933 times)
uclabiker06
"The time you enjoy wasting isn't wasted"
« Reply #15 on: June 02, 2013, 04:53:16 PM »
I'm going to assume thats a good thing
2006 S2R
2009 Smart
suzyj
Does my bum look big on this?
« Reply #16 on: June 02, 2013, 04:59:38 PM »
All electrons take a new path in suzyj's setup!
BK
Yes, I like to show the electrons who's boss.
uclabiker06
« Reply #17 on: June 02, 2013, 05:53:47 PM »
I'm about to show the box that the regulator is mounted on who's boss; with this hacksaw I have here
2006 S2R
2009 Smart
xsephirot
« Reply #18 on: June 03, 2013, 06:44:29 AM »
suzy please please please make a kit of your electronic wiring! I love that everything is so clean and you have that electronic board thingy that acts in place of fuses  bow down bow down
memper
« Reply #19 on: June 03, 2013, 10:53:52 AM »
I mounted mine under the bottom triple tree with the fins facing downward. Didn't have to lengthen any wires though I did delete the connectors and straight soldered it.
For mounting I just made two L brackets which are bolted to the holes where the headlight U bracket connects.
« Last Edit: June 03, 2013, 10:55:38 AM by memper » Logged
muskrat
« Reply #20 on: June 03, 2013, 05:11:54 PM »
well we are waiting to battle pics....pronto!
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Privateer
« Reply #21 on: June 03, 2013, 05:35:10 PM »
this only has one bolt, i later ran a piece of alum bar across and put a second bolt through it.
total cost about $4
uclabiker06
« Reply #22 on: June 04, 2013, 06:01:42 PM »
 waytogo  Wonder if that setup works with the rain
« Last Edit: June 04, 2013, 06:09:32 PM by uclabiker06 » Logged
2006 S2R
2009 Smart
jerryz
« Reply #23 on: June 06, 2013, 05:00:27 AM »
On my S4 i made up a 6mm thick aluminium plate to fit the mounting hole under the seat  and also acts as a good heatsink , the plate is slightly bigger than the regulator  and the regulator is also mounted upside down for more air flow ,
it runs much cooler than before .
BK_856er
2007 M695; 2004 749s
« Reply #24 on: June 12, 2013, 12:25:12 PM »
So I printed out the Shindengen dimensions and I'm scratching my head trying to figure out if I can make it work in the stock location.  Bolt pattern is different, but that's easily solved.  Space looks iffy.  Is the Hot Shot a drop in?
BK
I had some communications with Ricks Motorsport Electrics on this topic, so I will answer my own question.  Their "Hot Shot" is a cooler running mosfet type R/R and it has overall dimensions and bolt pattern to fit the stock location on my monster.  Wire length and connector ends hook right up, although if I were going to the trouble I'd convert to sealed Metric-Pack connections.  14.8V output setpoint.  Not sure it's "better" than the Shindegen, but it would seem to drop right in for similar $$.
BK
tuxicle
« Reply #25 on: June 12, 2013, 12:57:16 PM »
I mounted my Shindengen to the same spot where the old one was (using just one bolt). The connectors interfered with the tool box under the seat. A few minutes with a dremel, and it fit just fine. The MOSFET units can be left under the seat, since they don't heat up, even after extended rides. I butt-spliced some 14 AWG teflon insulated wire from the alternator to the Furukawa connector, and wrapped the bundle in some polyester expandable tubing. This got rid of the white plastic spade connectors that are often a failure point.
2008 M695
BK_856er
« Reply #26 on: June 12, 2013, 03:59:36 PM »
That's what I was thinking - rotate the Shindengen 180 degrees and dremel the underseat toolbox for clearance.  You also have a 695, so our requirements should be very similar.  Cool.
BK
Pages: 1 [2]   Go Up
