January 07, 2025, 01:19:01 PM
Voltage regulator relocation
Topic: Voltage regulator relocation (Read 9890 times)
muskrat
May 31, 2013, 06:02:21 AM »
I know the subject is around but I want to relocate without going to an open crank case. Thoughts? I'm not sure the wire is long enough to stretch to the underside. I have an 06 S4r.
Thanks
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
xsephirot
Re: Voltage regulator relocation
May 31, 2013, 07:40:36 AM »
Are you running a mosfet regulator already?
My stock one burned out last year and I mounted it directly under the plastic. It's quite a tough plastic that I had to drill through. I didn't feel like fabricating an aluminum cut like some members have done here so if you're lazy like me, you can mount it directly under. The lines *should* reach if you put it more forward
muskrat
May 31, 2013, 02:10:15 PM »
mine is stock but I'm afraid of it as it gets hot as hell. I'll pull the seat and see how much room I have to fool with it. Do you have a pic of your mod?
Thanks.
2015 MTS 1200
09 Electra Glide
suzyj
Does my bum look big on this?
May 31, 2013, 03:57:38 PM »
If you're going to the effort of moving it, move it as far as the bin and put a Shindengen FH020AA MOSFET one on instead.
Works heaps betterer.
http://roadstercycle.com/
May 31, 2013, 09:39:16 PM »
I checked on my S4, and it wasn't possible to move it to an inconspicuous location that had some airflow, without modding the wiring.
It's an ugly widget, so I left it in the stock location.
Honestly, suzyj has the sage advice, ditch the Fred Flintstone tech OEM unit and you can leave it where it is.
uclabiker06
"The time you enjoy wasting isn't wasted"
May 31, 2013, 10:48:12 PM »
My lack of electrical knowledge makes me a bit hesitant about the Sindengen option but its good to know there is a option for a replacement unit of quality other than OEM. Wonder if there is a write up or any pics of a Shindingen on a Monster.
So it wont interfere with a PC3 or anything like that? Oh and how/why is it better than OEM regulator?
Last Edit: May 31, 2013, 10:51:15 PM by uclabiker06
2006 S2R
2009 Smart
muskrat
June 01, 2013, 07:09:29 AM »
Quote from: Speeddog on May 31, 2013, 09:39:16 PM
so it does run significantly cooler?
2015 MTS 1200
09 Electra Glide
suzyj
June 01, 2013, 04:14:10 PM »
A normal rectifier/regulator uses diodes and SCRs. An SCR is a diode that can be turned on with a gate control. When the stator voltage gets too high (when you're revving hard), the SCRs are turned on, shorting out the stator and thus limiting the voltage.
The trouble is, when you turn on an SCR, you get a couple of volts drop across it. This voltage, combined with the current from the stator is dissipated as heat by the unit. Quite a bit of heat.
A MOSFET regulator uses MOSFETs in place of the SCRs. When you turn a MOSFET on, it looks like a resistor rather than a voltage. Depending on the size of the MOSFET, the voltage drop across it can be very low (like tens of millivolts), so the amount of power that the rectifier/regulator has to dissipate can be significantly less.
Note I said can be. If you use cheap parts, you can make a MOSFET rectifier/regulator that's every bit as bad as an SCR one. The Shindengen one however is pretty good.
Also, there are still diodes in the rectifier/regulator. These have around 0.7 to 1V drop, so they're still a significant source of heat. You cold use MOSFETs here too, and end up with very little dissipation, but to my knowledge nobody does this yet.
MOSFET rectifier regulators have nothing in them that will "interfere" with electronics on the bike.
TLDR: MOSFET rectifiers are betterer. They don't burn your bum.
I use one on my bike, though the electronics on my bike aren't exactly stock. See
http://www.ducatimonsterforum.org/index.php?topic=56614.msg1081527#msg1081527
Last Edit: June 01, 2013, 04:22:22 PM by suzyj
TitanMonsterS4R
June 01, 2013, 04:36:04 PM »
Not to make you even more worried, but the R/R on my 06 S4R burned out not too long ago. Ended up gettin a Hot Shot R/R from Rick's Motorsports. Uses MOSFET technology. Have been super happy with it since installed and the weather in DC has been blazing hot. Today was 95+ outside and felt ok doing a 2+ hour ride. Also have the same thing in my S4. No issues there as well after that one burned out. No relocation for their.
http://ricksmotorsportelectrics.com/part/10-008H/MDZEdWM5MTZNb25zdGVyTVM0Ug==
BK_856er
2007 M695; 2004 749s
June 02, 2013, 12:28:30 PM »
So I printed out the Shindengen dimensions and I'm scratching my head trying to figure out if I can make it work in the stock location. Bolt pattern is different, but that's easily solved. Space looks iffy. Is the Hot Shot a drop in?
BK
uclabiker06
June 02, 2013, 03:39:34 PM »
Just thinking of maybe trimming the box that the regulator sits on with a hacksaw. More specifically, chopping down the top of the box (the part right in front of the regulator). Then maybe somehow sealing it back up with epoxy. I think lowering the top of the box directly in front of the regulator would open up airflow by a good margin. Basically can cut a piece plexiglass or something the same shape as the border of the portion that was cut then use the epoxy as a sort of gasket; why not?
I have rerouted a handful of wires under the fuel tank. I also rerouted fuel lines (put them through the battery bracket for a cleaner look). As a result I'm sure I have restricted airflow to the regulator.
Last Edit: June 02, 2013, 04:46:38 PM by uclabiker06
2006 S2R
2009 Smart
suzyj
June 02, 2013, 04:03:01 PM »
TPO do a kit with a little filter that fits on your crankcase breather, plus plugs for your air box. Provides much better airflow for your rectifier.
suzyj
June 02, 2013, 04:09:13 PM »
Quote from: BK_856er on June 02, 2013, 12:28:30 PM
BK
I really doubt it'll fit on the breather, as its shorter, thicker, and considerably deeper due to the connectors. I moved mine quite a ways.
uclabiker06
June 02, 2013, 04:14:21 PM »
Yeah I know about the kit, just thought maybe that chopping & re-shaping the breather box would be another maybe easier alternative for dealing with the issue for those who wouldn't mind keeping the breather box instead of opening it up w/ breather filter. Thats a nice looking setup you got there btw. You change your battery?
Last Edit: June 02, 2013, 04:55:29 PM by uclabiker06
2006 S2R
2009 Smart
BK_856er
Reply #14 on:
June 02, 2013, 04:48:51 PM »
Quote from: uclabiker06 on June 02, 2013, 04:14:21 PM
.... You change your battery?
All electrons take a new path in suzyj's setup!
BK
