February 24, 2025, 03:55:06 PM *
Author Topic: Ducabike rearsets; shift linkage Q  (Read 1041 times)
hyflight
« on: June 03, 2013, 06:31:20 AM »
2010 Monster 1100.  Installed Ducabike rearsets, mostly an easy job.  I have the ball joints adjusted out as far as I think allows enough threads to remain within the tie-rod.  The shift pedal, therefore, is too high for my comfort...quite a bit higher than with the OEM rearsets.  Is there an aftermarket, longer, tie-rod available?  If I rotate the gearchange lever on the splines, will that affect anything other than shift pedal position?
Thanks!
« Reply #1 on: June 03, 2013, 07:30:02 AM »
Just rotate the lever to a new position on the splines, and check to make sure it shifts both directions.
Adjust to suit.
I am Sofa King
idiot sans savant.
« Reply #2 on: June 03, 2013, 07:33:54 PM »
what Nick said, just make sure to mark the current position with a sharpie, then rotate it one spline at a time until it's comfortable.
rule62
« Reply #3 on: June 04, 2013, 08:25:32 AM »
Or turn it 180 degrees on the splines and go with gp-shift pattern.  Wink  1 up, 5 down
Skybarney
Fako
« Reply #4 on: June 04, 2013, 08:30:11 AM »
There is a great video of a guy almost going over a bridge that had recently changed to GP style shifting.  After 30+ years of training my muscle memory I am gonna skip the flip.......
Found the link
