April 30, 2024, 12:18:21 AM
Monster 620 Neutral switch?
Topic: Monster 620 Neutral switch? (Read 1173 times)
Bun-bun
2002 M620 Dark ie
July 04, 2008, 02:10:33 PM »
I have an '02 M620ie and the neutral light on the gauge cluster just up and quit working. I know that the light is good, as it goes on when the gauges cycle at startup. I expect thast there is a switch somewhere on the bike that has decided to die, and my question is: where would I look for that switch?
Any help would be appreciated.
Jeff
Re: Monster 620 Neutral switch?
July 04, 2008, 04:53:54 PM »
The switch is in the back of the engine in a recess. There is a single wire attached to it. If you ground that wire with the key on the neutral light should illuminate.
Bun-bun
2002 M620 Dark ie
July 04, 2008, 07:19:03 PM »
Thanks Howie.
I'll check it out tomorrow.
Happy Independence day to you (Assuming you're in the states, of course.).
Jeff
Bun-bun
2002 M620 Dark ie
July 05, 2008, 07:49:50 AM »
Found it.
Wire pulled off the switch.
Once I knew where to look it was obvious.
Thanks again Howie.
Jeff
