February 04, 2025, 10:01:28 PM
Please Help
Awesome 7500 Mile Service Pictures
Topic: Awesome 7500 Mile Service Pictures (Read 1933 times)
JimmyTheDriver
June 06, 2013, 01:23:29 PM »
I posted this in CAM, but figured most of you don't look in there. Recently had my bike in for 7500 mile service at Richmond Superbike. They snapped some pretty neat pictures throughout the process.
nickshelby500kr
Re: Awesome 7500 Mile Service Pictures
June 06, 2013, 06:45:39 PM »
Pretty awesome little shim chart they have there.
DucRS
June 06, 2013, 08:25:22 PM »
Nice!
I've always been a bit of a skeptic about my services without
actually being there to inspect the work myself.
I know what I'll be asking for next time I drop it off for servicing,
"plenty of pics" please.
Black S4RS Black Multi S - Sold
Carbon Red Diavel ST4S abs - Sold
620 Red.
ZLTFUL
WWSDD? Why Anal of course!
June 07, 2013, 07:52:54 AM »
I was seriously confused there for a minute as my 7500 mile service was an oil change, a couple of service bulletins for the anti-freeze and rear brake and a chain lube and adjustment.
Then I remembered that the 7500 mile for the 9XX engines is way more intensive. The 1198 motor doesn't need valves checked til 15k.
Avatar courtesy of
www.mybadco.com
2012 Panigale 1199
2003 KTM 640 Adventure
JimmyTheDriver
June 07, 2013, 08:09:34 AM »
Haha yeah. They dig pretty deep. I was weary about spending 1k+ to get my bike serviced but the pictures at least give me some comfort they did what they said they would.
-Jim
Blue
Oh no, not another
2000 M900ie Dark
June 07, 2013, 08:10:20 AM »
Thanks for posting the pictures; it is cool to see how the bike it put together.
Really nice access to the shims. Would anyone say it would be easier to shim than a 2V?
nickshelby500kr
June 07, 2013, 08:59:41 AM »
Quote from: Blue on June 07, 2013, 08:10:20 AM
Generally 4v valve jobs are not as easy due to the extra labor involved as there is twice as many valves to do.
This method may be "easier" but it would be more time consuming tearing the heads down that far removing the cams.
Omnipotent Potentate
Personal Pretext
June 07, 2013, 09:12:15 AM »
The more modern 4v heads have nice access, as the whole top lifts off. The Desmoquattro - like the S4 are giant pains in the ass.
2v access is pretty generous - not hard to get in there at all
June 07, 2013, 01:08:00 PM »
~~~SNIP~~~
Oh hell no.
Quote from: Slide Panda on June 07, 2013, 09:12:15 AM
Yes, the TestaStretta access *looks* nice.
Once you take the radiator off (which you don't have to do on a DesmoQuattro).
Reassembly is a lot more labor intensive as all the sealing surfaces of the valve cover gasket and where the cam caps and cam shaft seals and end cap seals have to be cleaned thoroughly.
Then the cam caps have to be gooped up (but not too much!) and you've got to watch the cam shaft seals that they go in straight, and also the end caps, which are virtually inaccessible behind the electronics package on an SBK, at least the horizontal.
And the valve cover has to be gooped up a bit too (but not too much!).
Then you hope it doesn't leak oil after it's *all* reassembled.
SBK?
You've got to take 19 fasteners off just to get the fairing lowers off a 848/1098/1198.
And you've got to take *all* of the bodywork off too, well, except the tail.
Here's all the stuff that has to come off, except the airbox, this was a special case:
Sorry, rant over.
Carry on.
Rob Hilding
June 07, 2013, 04:37:01 PM »
Quote from: Speeddog on June 07, 2013, 01:08:00 PM
Oh hell no.
SBK?
Sorry, rant over.
Carry on.
You techs are allus pregnant dogin'
I think I'll stick to my 2V old school monsters and the like
SpikeC
Spike in PDX
June 07, 2013, 05:01:31 PM »
This is one big reason why I went with the M1100S!
edit: plus I examined what I really wanted/needed in a bike!
Spike Cornelius
PDX
2008 Bimota DB5R woo-Hoo!
1965 T100SC
brad black
June 07, 2013, 06:24:35 PM »
Oh hell no.
SBK?
Sorry, rant over.
Carry on.
rant away big fella.
what he said. testa give me the shits, and all the cleaning just drives me nuts. at least 1098 only have caps on the rh side. nothing like trying the get the collets back onto the horiz inlet valves on a testa to make you work a little blue.
you can pull the 1098 rad out to the lh to save taking it all out, like an 888, but do you have to remove the air runners to get to the mounts? I forget now. and there's always a good reason to pull an 848/1098/1198 airbox off: to shake all the dirt out of it.
altho, doing the cam timing on a testa is easy, esp with the factory lift tool. it's way cool.
desmoquattro are much easier to work on, even if the vertical exhaust access is a little tight on the drop cam ones.
I generally find 2v a little therapeutic. except when I have to get medieval removing shims.
Brad The Bike Boy
http://www.bikeboy.org
June 08, 2013, 06:29:06 PM »
Quote from: brad black on June 07, 2013, 06:24:35 PM
~~~SNIP~~~
The last 4-valvers I've done have been 749S, and 2 of 999R.
All with the 6mm valve stems.
IMO, the peak of maintenance unfriendly.
Tho the 848/1098/1198 shock removal makes up for whatever they made slightly easier on the motor.
The factory has 3-D CAD modeling, and if you're paying attention, you can make it easy and quick to assemble on the line, *and* easy to maintain and service.
brad black
June 09, 2013, 12:37:51 AM »
Quote from: Speeddog on June 08, 2013, 06:29:06 PM
I don't have any of the tools to do the 6mm valve stem heads. I have one 749s that will need it done next time, heads will go to Sydney so shaun can do them.
why do you remove the 1098 shock. oh, you mean removing it in general for whatever reason? yes, I've not had to do that. watched the old boss do it once, I recall it being quite amusing.
Brad The Bike Boy
SDRider
Pregnant Dogin'
Reply #14 on:
June 10, 2013, 05:29:10 PM »
I had the tank off when I did my exhaust but didn't snap any pics of it like that. It is fun seeing what makes these bikes tick. I helped my friend adjust his valves and he just changed his belts too. We're going to do mine this summer at some point whenever I hit 15,000 miles. I'm less than 3k away from that mark. Should be fun doing those belts with the way the exhaust is routed on my bike...
Last Edit: June 10, 2013, 05:31:25 PM by SDRider
2014 Ducati Multistrada 1200 S
2012 Ducati Monster 1100 EVO (sold)
