Clutch not disengaging fully
Started by atlbikenight, June 06, 2013, 02:53:16 PM
I don't think the pushrod is properly seated in the screw or the piston.
Quote from: Speeddog on June 08, 2013, 08:38:39 PM
That's also known to happen (been there, done that)
Theory: there's a spring on the left of the adjuster screw - it works like a set screw to prevent the adjuster from moving. Maybe you backed out the adjuster too far... letting the spring into the path of the adjuster and blocking it from it's path...  :-\
suzyj
Also, maybe you need to bleed it.
Clutch bleeding is fun.
kokis
I am not pro in tech questions, but as any rider have some experience that I can share without claiming to absolute truth. Please use my advices responsibly.
atlbikenight
Quote from: stopintime on June 09, 2013, 01:49:57 AM
stopntime this is exactly what happened. now i just need to find my inner mcgyver to figure out how to move the spring out of the way to get the screw closer to the push rod
atlbikenight
problem solved!!!! thanks to everyone for their input. no more ducati dealership
atlbikenight
So I apparently have discovered the REAL problem here. The clutch was fine (yes the screw needed to be pushed in a bit more closer to the pushrod) but the initial cause was the dealer barely put 2 liters of oil in the bike. I went to do an oil change on it over the weekend and I was shocked how much (or little) came out. After changing the oil and filter there was a worlds difference in response to the clutch and engine temp. Damn dealers do not have a clue what they're doing these days.
Duc796canada
796 Red Monster(sans ABS)
Viz-Tec Supabrake II
15/41 gearing(AFAM quick change sprocket)
PC V, NEXTUP QS.
2006 Suzuki GSXR 600 track bike(I know...not a Duc...some day)
