Clutch not disengaging fully
Started by atlbikenight, June 06, 2013, 02:53:16 PM
atlbikenight
I took my 2011 Ducati Monster to my local dealer to have the 14 tooth sprocket installed. While I was there I went ahead and told them to go ahead and change the oil since they had the bike in the shop. When they finished everything the tech went to take it for a test drive and the clutch would not engage. I rode the bike to the shop with no problems and to/from work the week prior. They took the clutch cover off and found out that my clutch was not fully disengaging when the lever was in its nuetral position and that my clutch lever may not have been machined correctly and was causing fluid to back up in the clutch system. I have never heard of this problem before. they said the simple remedy was to buy a new clutch lever. I have a set of rizomo break and clutch levers on the bike. Is there anyway I can modify the levers to avoid purchasing new ones or any other kind of solution you guys can think of to avoid this problem in the future?
Dirty Duc
On many levers there is an adjustment for the plunger.
atlbikenight
I figured that much. Isn't that something the shop would know about? And I was wrong on the brand they are Ride It shorty levers not Rizomo. Where would I find the adjustment for the plunger?
Dirty Duc
Quote from: atlbikenight on June 06, 2013, 03:01:20 PM
Do they sell levers?  A pretty easy upsell... and then they still have the "wrong" take off to fix some crashed bike....
Which Monster do you have?  Depending on the model, the adjuster might be slightly different.  The Ride It website does not show pictures of the appropriate part of the lever... pictures would definitely help here.
Quote
This description is a little less than accurate, so if that is what they told you I'd find another shop.  The fluid isn't "backing up," it is doing what it is supposed to do... transfer energy from the lever to the clutch actuator rod through the hydraulic system that is the master/slave/hose arrangement.  If your lever is not adjusted properly it will hold the master cylinder in a "squeezed" or partially squeezed position... and hold the clutch in the disengaged or partially disengaged position.
If it didn't do it before, and now it does, then they adjusted it out of spec (through lack of knowledge or to bump up their profit margin) or otherwise boogered it.
atlbikenight
its a 2011 monster 796. im picking it up on saturday ill try and get more details when i pick it up. they said they fixed it but if i continue to use that clutch lever it will happen again even though i never had an issue with the clutch or lever
Ddan
Quote from: atlbikenight on June 06, 2013, 02:53:16 PM
This sounds like bullshit to me.  I'm not sure what master cylinder you have but the bleed back adjustment is usually on the master not the lever.  Any adjustment on the lever is only for lever travel and shouldn't have any effect on the master.
Ducati Monster Forum at
www.ducatimonsterforum.org
Bleed back screw is in the lever on coffins.
Ddan
Quote from: ducpainter on June 07, 2013, 03:20:03 AM
Still doesn't explain the 'poorly machined lever' excuse for a set-up that was working until the shop got to it.
atlbikenight
I emailed ride it moto and they sent me a diagram of how to adjust the screw to alleviate the problem. I pick it up tomorrow morning so we will see if that solves the problem. The parts department did happen to have "one stock clutch lever" in stock apparently. Sounds like I need to find a new shop.
atlbikenight
so according to the dealer the nut and pin is not coming out all the way when the clutch is released. i took the entire thing apart and checked under the fluid cap and nothing looked out of ordinary. put it all back together and test drove around the block. it is really hard to kick into nuetral with the bike is running but kicks into n easily as soon as i shut it off. not sure if its fully engaging or disengaging now. see photo and any tips?
atlbikenight
As it's' adjusted now, it's likely not pushing the plunger (pin in the rubber) deep enough.
Try 'a few' turns in  [thumbsup]
If you want to do it properly:
http://www.ducatisuite.com/leverchange.html
(scroll down)
Ddan
Quote from: stopintime on June 08, 2013, 05:20:16 PM
(scroll down)
+1
Having problems finding neutral with it running is usually a symptom of not fully disengaging
atlbikenight
i cannot get it to screw in any farther than that. I will probably have to take it all a part and follow the instructions posted by stopntime. Thanks for all the help guys
