January 08, 2025, 09:38:17 AM *
Author Topic: How to measure exhaust springs?  (Read 3299 times)
Blue
Oh no, not another
2000 M900ie Dark
« on: June 11, 2013, 06:57:30 PM »
I picked up a set of high mount exhausts for my 2000 M900ie.  The cans are held to the mid-pipes with two springs, one top and one bottom.  The pipes came with 3 of 4 springs and I need to know how they are measured in order to order another spring.  Are they measure from coil to coil (~51mm) or from hook to hook (~80mm).  Thanks for the help. waytogo
« Reply #1 on: June 12, 2013, 01:31:21 AM »
Inside of hook to inside of hook.
Blue
Oh no, not another
2000 M900ie Dark
« Reply #2 on: June 12, 2013, 06:14:08 AM »
Thanks!
Now, I might be dwelling on this too much but measuring the used spring as stated above came back at 78mm.  I found springs at 75mm and 80mm.  Should I assume that the spring has stretched and was originally 75mm?  Also, the spring gap from exhaust to midpipe is ~95mm top and bottom if this helps to determine the spring length.  Is there a rule for this?
Thanks again. waytogo
« Reply #3 on: June 12, 2013, 08:44:24 AM »
I wouldn't assume that the spring has stretched. Chances are that's the length they were made.
The only 'guideline' I know of is you want the installed length not more than 20% more than the free length.
If you do the math 78 mm is 18%, 75 is 22%, and 80 is 16%. I think the numbers are close enough you could use either.
I think I'd go with the 80mm springs. They'll give you less trouble installing.
Blue
Oh no, not another
2000 M900ie Dark
« Reply #4 on: June 12, 2013, 12:34:39 PM »
Thanks for the help; I will get the springs ordered soon.  I will be going for the 80mm springs.
