February 24, 2025, 04:01:49 PM
Headlight Mounts
Topic: Headlight Mounts (Read 3299 times)
Gossamer_in_FLL
Headlight Mounts
June 13, 2013, 09:55:42 AM »
Some of you guys that have changed your headlight may be able to help me with this.
I'm looking for inexpensive but not ugly headlight mounts for the Monster's 55mm forks. Seems like these are such big forks that there aren't many options for mounts for a headlight
Do any of you have any links that can help me complete my headlight project??
Thanks in advance guys.
zooom
Re: Headlight Mounts
June 13, 2013, 10:54:44 AM »
http://www.ducatimonsterforum.org/index.php?topic=63152.0
has a few links/ideas/information in that thread....search function works pretty well also.
2010 KTM 990 SM-T
Gossamer_in_FLL
June 13, 2013, 11:58:39 AM »
Quote from: zooom on June 13, 2013, 10:54:44 AM
Thanks big guy. I've seen and interacted with some of the people that posted in that particular thread and trust me, I wouldn't be asking if I hadn't searched first.
Stormtrooper
2011 Monster 796 ABS
June 13, 2013, 03:04:56 PM »
@FLL - I've been waiting to see what you have up your sleeve with that headlight project!
The crime scene choppers mount is always an option if you don't wanna fuss with the forks...
Rudemouthsky
Autonomous red and black
No gods and no masters
June 13, 2013, 05:58:47 PM »
I ordered the "Stealth Brackets" Monsterparts sells. 55mm? What year is your Monster, mine mic'ed at 53.7
Gossamer_in_FLL
June 14, 2013, 05:44:11 AM »
Quote from: Stormtrooper on June 13, 2013, 03:04:56 PM
I thought about that mount, but I'm going for more of a "vintage" look so I'm thinking of using the classic fork mounts...if I can find them. However, the idea of mounting it on the crime city mount and making the bucket appear as if it's "floating" REALLY intrigues me.
Quote from: Buck Naked on June 13, 2013, 05:58:47 PM
You're right Buck...it's 50mm at the top and 54mm at the bottom. Now that I'm searching for the right size, I've found a few options but nothing definitive yet.
Rudemouthsky
June 14, 2013, 07:28:49 AM »
Not 100% but I *think* fork mounted clamps need to be mounted on the narrower (top) end, otherwise the lower triple will interfere. That would increase your options.
The CNC Racing collars are what I was originally gonna go with but they are pricey and I'm not sure I like the look of them. I have a lower triple headlight clamp for sale in the classifieds, fits the Corse Dynamics headlight and all bottom mounted universal headlights.
actually it looks like it would provide the exact same mounting option as that CSC bracket.
Last Edit: June 14, 2013, 07:30:53 AM by Buck Naked
theoneillusion
June 14, 2013, 07:01:55 PM »
Here is what I just installed. Really like 'em, and well made. Fits 50/52/54mm forks. Don't mind the subpar wiring job, I've got to refigure that part.
http://imageshack.us/a/img835/6098/z1yq.jpg
http://imageshack.us/a/img694/5811/mks5.jpg
http://imageshack.us/a/img12/640/7r09.jpg
Rudemouthsky
June 15, 2013, 04:58:25 AM »
Those look nice...kinda wish I hadn't cancelled my order for em'. Only reason I did was I bought the CD kit which I ended up hating...might get these after all if the "stealth" brackets I ordered don't work out.
Gossamer_in_FLL
June 17, 2013, 05:07:11 AM »
Quote from: theoneillusion on June 14, 2013, 07:01:55 PM
Those look great Illusion!! Where did you get them??
theoneillusion
June 17, 2013, 04:37:12 PM »
They're made by highsider and come in black or polished aluminum. Looks like they are in stock now.
Just a note, because of the 50/54mm diameter change of the forks you are limited in where you can mount it vertically. I have the top shimmed for 50 and no shims in the bottom and it jussstttt fits across the bevel between the differing diameters. Fits perfect for allowing you to mount your dashboard beneath the triple clamp, lowering it a bit.
http://www.bikermart.co.uk/proddetail.asp?prod=220-604-18&cat=117
http://www.bikermart.co.uk/proddetail.asp?prod=220-605-19&cat=117
Last Edit: June 17, 2013, 04:40:45 PM by theoneillusion
Gossamer_in_FLL
June 18, 2013, 05:20:08 AM »
Quote from: theoneillusion on June 17, 2013, 04:37:12 PM
Thanks Illusion...these are GREAT!! Unfortunately, not cost effective...but they do give me a good idea
