No start
Started by JoshuaCJCohen, June 18, 2013, 08:37:24 AM
JoshuaCJCohen
Ok.  I have since filled the tank and because of my crappy after market cap system I can't lift the tank. So for now I'm living with a very slow leak.  It appears under the rubber housing that hides the wires.  Whenever I pull the rubber down there is a slight amount of moisture in there.  It would appear the internal o-ring is not seated correctly.  When I burn some gas down I'll snug it  up some more.
BTW, when I first started it I had to jump it but I rode it around the block for 20 minutes and then shut it down.  Started up it a little while later and it fired up first time.  Fuel pumps are priming and the starter is turning over.  There is a bit of hesitation with the starter but before this all started the fuel pumps wouldn't prime at all.  If there is a starter issue I think it's a separate issue.  Once I get my road documents in order (driving in Japan is a bureaucratic nightmare) and the slow lead handled I'll be able to look more closely at the starter.
Thanks,
Josh
It sounds like the sending unit is leaking through the epoxy potting.
Tightening won't stop it.
JoshuaCJCohen
New sending unit?  Any after market ones or only through the dealers?
Quote from: JoshuaCJCohen on September 14, 2013, 07:10:59 AM
Yes...a new one.
Dealer item or used. They are pricey new, but you know what it's like to take the tank internals out. Do you want to gamble on a used one not working?
I would go new.
