February 24, 2025, 05:14:04 AM
Please Help
Fuel overflow and breather tube questions
Topic: Fuel overflow and breather tube questions (Read 1123 times)
iltl32
June 19, 2013, 02:31:12 PM »
The '05 620 Dark I just bought has had the fuel overflow breather tubes removed, and I'm not sure which port is which on the fuel tank. Can anyone tell me?
Also, if anyone could explain where the overflow tube is supposed to wrap through the frame, that would be awesome. I can't seem to find a good place where it won't touch the engine or get snagged on anything moving.
Thanks.
Last Edit: June 20, 2013, 09:50:30 AM by iltl32
2005 620 Dark
suzyj
Does my bum look big on this?
Re: Dual overflow anad breather tube questions
June 19, 2013, 02:39:15 PM »
There are two ports which join together on my tank with a y piece, then drop straight down the back of the motor on the right side, between the swingarm and motor. There's a little bent bit of wire bolted down with a clutch cover bolt that locates the end of the tube.
It does touch the engine, but on a cool part behind the gearbox rather than near the heads where it would melt.
iltl32
Re: Fuel overflow and breather tube questions
June 20, 2013, 11:35:06 AM »
Are you not in the U.S.? We have one that needs to go into the pollution cannister, and the one for fuel overflow. I don't want to mix them up and dumb excess fuel where it doesn't belong.
2005 620 Dark
memper
June 20, 2013, 11:53:24 AM »
US or not, what I believe Suzy is describing is the routing after doing the "emissions canister delete mod".
SpikeC
Spike in PDX
June 20, 2013, 12:29:54 PM »
And given the difference in size of the tubes it is not possible to mix them up. They did that for this very reason.
Spike Cornelius
PDX
2008 Bimota DB5R woo-Hoo!
1965 T100SC
iltl32
June 24, 2013, 05:53:49 AM »
The tubes are gone, and the 2 ports appear to be the same size.
2005 620 Dark
June 25, 2013, 02:50:55 AM »
Quote from: iltl32 on June 24, 2013, 05:53:49 AM
Spike was referencing the drain/vent compared to the fuel supply/return.
iltl32
June 26, 2013, 03:40:27 PM »
So... can anyone tell me which port is which?
2005 620 Dark
Enjoying the ride
June 26, 2013, 04:41:09 PM »
my 620 has two lines at the bottom, clearly marked in/out
hope these help:
fuel lines 2
fuel lines 1
June 26, 2013, 05:01:45 PM »
Quote from: iltl32 on June 26, 2013, 03:40:27 PM
Do you have access to an air compressor?
Blow air in one end and it should come out the other.
If memory serves...the tube closest to the tank edge is the drain.
