February 24, 2025, 04:43:43 PM *
Pages: [1] 2   Go Down
Author Topic: 06 Tank on a 98?  (Read 2054 times)
ChrisK
« on: June 26, 2013, 09:11:11 AM »
I know there's the thread "All About Fuel Tanks," but for some reason I'm having a hard time understanding it.
Will a tank from an 06 S2R 800 fit a 98 carbed bike? I'm guessing the answer is that they're different, and I'm curious about what makes them different.
1998 M900
2007 CBR600RR Track Bike
1980 Lambretta Moped
Supra Boats enthusiast
Dirty Duc
I'd rather be an anti-
« Reply #1 on: June 26, 2013, 09:20:10 AM »
The big differences are material and the underside of the tank.  The plastic tanks have a big hole with a flange that holds the fuel pump, fuel filter, pressure regulator, and inlet/outlets.  The shape of the underside is slightly different, but I don't think that is a problem here.
The easy way to do that is with the CA-cycleworks tank flange.
You'll also need the hinge and mount for the plastic tank and maybe the plastic tank catch at the front (because I don't know if the 98 catch has the same attachment scheme to the tank).
You'll lose about 2 gallons of fuel capacity, and gain the expansion issues associated with the plastic tanks (but you'll also gain dent-proofness).
ChrisK
« Reply #2 on: June 26, 2013, 09:56:28 AM »
Thanks Dirty Duc, that helped convince me not to purchase a particular tank on ebay.
What tanks will be headache free for me when installing?
1998 M900
Dirty Duc
« Reply #3 on: June 26, 2013, 10:04:19 AM »
Any carb'ed Monster should be the same.  All 93-99, and some 00-01 (the turn of the century led to a "casual" transition to fuel injection).
The metal fuel injected tanks look very similar on the outside, but they have all the fuel pump, etc. inside the tank.  I'm also not sure what the front latch piece looks like.
« Reply #4 on: June 26, 2013, 10:14:35 AM »
Any late...2K up carbed tank will also have a different seat cutout.
ChrisK
« Reply #5 on: June 26, 2013, 10:18:32 AM »
DP, in that other thread I remember reading that the seat cutout is just slightly different? How big of a difference is "slightly."
I've honestly always wondered if my seat or tank were mismatched, because they never seemed quite right. I wouldn't know how to tell though.
1998 M900
ChrisK
« Reply #6 on: June 26, 2013, 10:21:01 AM »
Also, take this tank on ebay for reference: http://www.ebay.com/itm/161027328557?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
If you scroll all the way down to the last two pictures, the nipples (or whatever you want to call them) are in a different orientation than the ones on my tank. However the labeling for them contains the same names (drain, delivery, and bleed). So, I have two questions about it: does the orientation of them matter? Are those things rusted and deformed beyond use?
1998 M900
« Reply #7 on: June 26, 2013, 10:30:34 AM »
The seat cutout is about an inch longer on the later tanks.
If you have a large gap between the seat and tank you have an early seat and a later tank.
The upside is all the later seats will work whether it came from a steel or plastic tank.
ChrisK
« Reply #8 on: June 26, 2013, 10:34:32 AM »
Okay thanks DP.
Anyone have thoughts on my questions about those nipples?
1998 M900
Dirty Duc
« Reply #9 on: June 26, 2013, 11:01:52 AM »
Borked.
Move on to something easy like a dent.
« Reply #10 on: June 26, 2013, 11:15:05 AM »
That is a very early tank.
I'd skip it because of the delivery nipple being broken...never saw a tank with that...and it's probably rusty as hell inside.
SpikeC
Spike in PDX
« Reply #11 on: June 26, 2013, 11:37:04 AM »
 Holy smokes! Why would someone use side critters on the tubes?
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
Dirty Duc
« Reply #12 on: June 26, 2013, 11:41:32 AM »
Because there is not a minimum IQ requirement before touching a Ducati...
« Reply #13 on: June 26, 2013, 12:30:56 PM »
From the looks of the sharpie marking on the inside left lump, I suspect they were trying to fit it onto an S4.
Lost cause, that.
« Reply #14 on: June 26, 2013, 12:45:50 PM »
If you can get that tank cheap enough (close to free) it could might pay to send it off to ducpainter for reconditioning,  assuming he could do something with those severely circumcised nipples and keep the cost reasonable.
Pages: [1] 2   Go Up
