696 Speedo Not working
Started by kuzemko, July 03, 2013, 08:24:53 AM
kuzemko
So I googled a bit, but either my skills aren't up to par or nothing was posted, but...
I did a tail tuck and cleaned up the rear of the bike. I used all the stock wiring, and didn't cut/splice into anything. Only non-stock light used is the one for the license plate. After I installed it, it rained a bit, and today on my way to work, I noticed that my speedo isn't working. The rest of the info on the dash works/tracks fine, but my speed is stuck at 0 mph. Did I miss anything during the installation? Would the undertail kit have anything to do with it? (not sure how speed is tracked) Anybody else have similar issue or any idea where I can check first?
Thanks for the help!
www.kuzemko.com
Stella - 2010 696
kuzemko
Nevermind! On the ride home from work, it worked just fine. I'm going to blame a little of it on PFM and most of it on the rain/humidity making the electronics not happy. After sitting in the heat while I was inside, it may have dried out... Or it was PFM. Any other thoughts?
www.kuzemko.com
Stella - 2010 696
kuzemko
Okay it's still happening intermittently. Any ideas why the speedo would just not work?
www.kuzemko.com
Stella - 2010 696
kuzemko
Along with the speedo, the mileage isn't tracking. Overall or the trip. Ugh. I'll see if I can find where the sensor tracks and check it. Not sure what else to do.
www.kuzemko.com
Stella - 2010 696
the speedo and mileage is picked up by the sensor on your brake mount.
follow that sensor and see if the connector is loose.
kuzemko
Quote from: Raux on July 05, 2013, 04:08:19 PM
I see the sensor on the brakes, but I lose the cable behind my right rearset. The sensor itself seems fine. Solidly mounted still. Nothin wrong with the wiring I can see. Seems like an odd thing to stop working...
www.kuzemko.com
Stella - 2010 696
I think i've read of the sensors going bad
craig697
Loosen off the tail tidy or remove and see if you pinched the wire when you did the install. I can check on mine tomorrow when I get home for the routing of the cable.
07 s2r1k
10 696
kuzemko
#9
Quote from: craig697 on July 05, 2013, 06:01:03 PM
I removed, inspected the wiring and cleaned up the routing of the cables. Used a few more zip-ties and some electrical tape to kind of bundle up and clean up the cabling. Everything looked fine with nothing exposed and good connections. All wiring is stock, didn't need to splice into anything for the install.
Quote from: Raux on July 05, 2013, 06:06:52 PM
btw which tail tidy?
Evotech. Found on fleabay, worked like a champ.
Side question: Would the tail section lighting have anything to do with the sensor for the speedo/mileage? I teach basic electronics for the navy and I don't see how these few wires in the harness would have anything to do with the sensor. Then again I don't know anything about the ECU programming.
Just realized my question sounded pretentious and kind of like an asshole. Not meant that way at all, just meant that I'm not a complete electronics noob. I AM however, a Monster Maintenance noob.
www.kuzemko.com
Stella - 2010 696
well for example.
when i put the Competition Werks tail tidy I blew the main fuse due to poor grounding and wiring routing.
it didn't look that way when i buttoned it up.
i replaced the fuse, took off the tail and returned it (really poor quality build)
have you checked all your fuses?
kuzemko
Quote from: Raux on July 05, 2013, 07:28:27 PM
well for example.
Didn't check any fuses, but the speedo has worked since the tail tidy. I was guessing loose connection somewhere, just need to find the non-sensor end of that wire. I'll check fuses in the morning to be sure though.
www.kuzemko.com
Stella - 2010 696
kuzemko
Fuses good, cabling is good, but new indications today tell me it's the sensor itself and not a connection. If the connection was loose, it would work intermittently. Instead when I started it today, while idling, the speed went from 0 to 67 to 21 to a few other numbers, then back to 0. As I drove off it changed a couple times and then back to 0. The sensor is bad... I just wish it was something easier/cheaper. Hopefully I can find them online for not too much. Ugh...
www.kuzemko.com
Stella - 2010 696
Quote from: kuzemko on July 06, 2013, 01:47:59 PM
find a friend and double check before buying
alibaba
I seem to recall reading over and over about failures in the speedo cluster after it got wet.  Didn't this problem start after riding in the rain?
Was the cure to dry it out with a hair dryer?
