February 24, 2025, 02:17:59 PM *
Author Topic: Will these Ohlins tubes fit a Monster?  (Read 930 times)
Skybarney
Fako
« on: July 03, 2013, 10:04:01 AM »
I found some used first generation $500.00 Ohlins fork tubes online.  The ad says it fits a first gen APRILIA MILLE/TUONO  I did some quick research and think they are the right diameter (43mm), The length at 29 inches top of tube to center of axle.  Gonna go measure mine but if any of you folks have some thoughts it may change how much research I need to do.
They will have to go back to Ohlins as they are setup for a 220lb rider.  Not sure if I am saving any real money or not by the time I get them and respring/valve them.
Thoughts?
nickshelby500kr
« Reply #1 on: July 03, 2013, 12:30:21 PM »
I would be curious as to whether the axle size and caliper bolt distance is the same too. Otherwise if the tube diameters are right then it will work. Just adjust how many lines are showing above the triple.
