For you Carbon Fiber freaks
Started by Raux, July 04, 2013, 03:59:57 PM
Skybarney
I am not sure whether to thank you or curse you.......   ;D
Quote from: Raux on July 04, 2013, 03:59:57 PM
"They are stronger and 40% lighter than aluminium bolts."
Two observations:
1) An aluminium bolt isn't very heavy anyway
2) An aluminium bolt isn't very strong
you can AL for side cases and several other connections on a Duc.
so you can replace the AL with CF
and Steel with Ti
just imagine the weight savings.
coduc
Be careful using carbon bolts to attach aluminum parts.  Galvanic corrosion is real bad between AL and CF.  Water/Moisture/Heat accentuates the problem....essentially, you aluminum parts will corrode away!
OT
Quote from: coduc on July 04, 2013, 07:10:08 PM
but is it any different than steel/AL/Ti issues?
SpikeC
 So the carbon fiber belt covers on my Monster are going to make the engine dissolve?
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
"The actual thread can not be stripped. In terms of dynamic strength carbon fibre is much superior to all other materials used for screws."
Can't be stripped eh... sounds like a challenge!
weemonster
OOOOH  But!!!
9 euros each!!!
Galvanic corrosion. (which is an Americanism btw) Between Aluminium and Carbon in air?
Oh deary me.
It happens on steel boats with Aluminium super structures but wouldn't happen without  salt water (electrolyte) or an electrical charge.
Also it needs to be 2 metals
So you Carbon Fibre bolts will not corrode your engine cases.
Fatal
May I just say, that all the Carbon Fibre in the world is not going to compensate for the Fat Flucker that is sitting on my Monster's seat ;) ;) ;)
Alan H
Pedro-bot
Quote from: Fatal on July 14, 2013, 03:08:10 AM
Alan H
+1  [laugh]
Or for those that are exercise challenged,
drop a deuce before each ride.
Immediate weight savings.
bond0087
Before anyone goes out and starts buying these up and changing out their engine cover bolts, keep in mind that when people say "carbon fiber" or "carbon" in this context, they mean carbon fiber reinforced plastic. So these bolts are plastic bolts with some carbon fibers in them.
Unlike most CF composite parts that you'll see for motorcycles, though, these use PEEK instead of epoxy. PEEK has a glass transition temperature of around 290 degrees F. That means that these will quit acting like a rigid material and start acting like a gel at that temperature. Will some engine cover bolts approach that temperature? Maybe, maybe not. Will your fancy plastic bolts result in your Duc "marking its territory" every time you park? Maybe, maybe not.
So keep that in mind before you spend all your money on plastic screws. Plus, if strength and temperature are really that much of a non-issue for a particular screw, you know what's even lighter than plastic with carbon fibers in it? Plastic without carbon fibers in it.  Plus, it's cheaper. :)
