February 24, 2025, 05:44:34 PM
"Mid Pipe"? For termis?
Topic: "Mid Pipe"? For termis? (Read 2931 times)
Kabulpostie
July 11, 2013, 08:01:37 PM »
I was looking at old Duc is the wild posts today and saw several pics of S2Rs with a different exhaust mount or configuration than I do..My pipes if you can see in my avatar sort of sweep up at a 45 degree angle. Many pics I have seen look like there are basically 2 90 degree bends that bring the pipes up and over the wheel. I love the SSS (One of the reasons I chose that model) and would like to show the wheel off more. It looks to me like there is simply a add on pipe to mount the cans higher... Is this the case? and if so is that middle section readily available?
Thanks,
From late night mod obsession help..
brad black
Re: "Mid Pipe"? For termis?
July 11, 2013, 10:56:31 PM »
it was a different muffler kit. what you have is quite rare. yours has the pipes into the muffler welded in? the other kits had them slipping on, so yours is totally different from memory.
only reference I found to your kit in the 2005 dp catalogue is with homolgated (ie, quiet) mufflers.
Brad The Bike Boy
http://www.bikeboy.org
S2R 800 '07
July 11, 2013, 11:27:32 PM »
They connect to the mid-pipes under the foot peg, like 'all' other exhaust systems.
You'd have to come up with a homemade bracket, between cans and frame, to mount them higher.
The extra plumbing you need is called S-pipes - haven't seen them for sale, but they are basic enough to fabricate for someone who does that sort of thing. As Brad mentions, if the little pipes going into the cans are welded on, you need a solution for that as well...
They are rare, and somewhat popular, so selling them and buying a slip on kit (which includes the S-pipes) is probably an easier solution.
This kit was not including the usual upgraded ECU, so tuning issues should be adressed if not already done.
Kabulpostie
July 12, 2013, 04:40:38 AM »
Thanks for the help. Unfortunately I don't have the bike here so I can't get a good look at the set up. I do seem to remember something about an ecu tune or chip or something in the documents provided by the PO.
I'll have to check it out in a couple of weeks when I get to the bike. Thanks again, I keep learning new things every day here!
Heath
July 12, 2013, 06:19:34 AM »
Here are your part numbers
Header or
Steel high-efficiency collector box for all exhaust kits for S2R 1000
# 979A00107
Slip-On's
Noise Compliant Carbon Lowered Side Silencers
# 96025704B
I have the same set up but for my S2R800. They are very nice. I should add neither of these came with an ECU. The PO might of done that on their own.
2007 Ducati Monster S4RT
Kabulpostie
July 14, 2013, 05:29:34 AM »
Thanks for the information. I'm having a hard time finding references for the part numbers. I googled them and get to the Ducati OEM site, but it doesn't let me search by part number..any ideas?
S2R 800 '07
July 14, 2013, 05:54:10 AM »
The stock S-pipes are available with individual parts numbers, but I seriously doubt they will fit against your cans.
I'm not sure the S-pipes included in the DP slip ons kit fit your cans either - the end outlet on your cans are wider as far as I know and that could mean the inlets are wider too ....
Kabulpostie
July 14, 2013, 06:06:12 AM »
I found a couple pics that might help, it's frustrating not being able to go the bike and check! I think I see what you guys are talking about..it looks like the last six inches or so of the pipe is part of the can, does that make sense?
[/url]
[/url]
S2R 800 '07
July 14, 2013, 06:29:27 AM »
Looking at the catalog pictures, yes they are welded.
(these cans are not listed for the S2R1000, but that's probably just a small mod challenge)
If it's important to keep these exact cans, you have to do quite a lot of welding/pipe and bracket fabrication.
Kabulpostie
July 14, 2013, 06:41:29 AM »
Hmm, the more I hear the more I like what I have lol
July 14, 2013, 10:35:06 AM »
you could swap out with someone with termis...
but honestly those are the BEST looking S2R pipes i've seen
brad black
July 14, 2013, 03:05:43 PM »
all s2r800, s2r1000 and s4r (996) muffler applications are the same. it's only the s4rs and the 07 onward s4r with the testa motor that are different.
Brad The Bike Boy
S2R 800 '07
July 14, 2013, 03:11:27 PM »
Quote from: brad black on July 14, 2013, 03:05:43 PM
If that's true, why does Ducati always list them (1000) as not? Header pipe differences? (even if it's just slip ons)
