chain adjuster ST4 2006 will fit Monster 2002?
Started by cmejia1978, July 25, 2013, 07:38:42 PM
cmejia1978
hi there, just broke my right chain adjuster so will a 2006 ST4 chain adjuster fit? 25mm? how do I measure the monster's 2002 620ie mm? thank you!  [bow_down] what will the difference with a Multistrada 2006 chain adjuster? I put a 916 ohlins + tie rod to the max extension on my Monster due to the fact that I modified my chassis for Cafe racer purposes  [drool] so... the which chain adjuster will fit better? now I am buying a Hyper kickstand just to be able to park the bike, due to the new "height" thank you for any advice at all!  [popcorn]
Well, for starters, there was no ST4 in 2006, replaced by ST3 and ST3 ABS.  Adjuster from an ST? steel swing arm should fit  a steel swing arm 25mm. steel swing arm Monster and 25mm. aluminum ST should fit an an aluminum 25mm. Monster.
Get your part numbers here:
http://www.ducatiusa.com/services/maintenance/index.do
cmejia1978
you are soo right! the ad says: 01 Ducati ST4 ST4S Swing Arm Swingarm Frame Adjusters Rear Axle
