Reuse/Replace green fuel filler cap o-ring (02 M620)
Started by nsherman2006, July 31, 2013, 12:08:26 PM
nsherman2006
Hello,
I recently repainted my M620 tank and need advice whether the green o-ring on the fuel filler clange should be reused or replaced?
If so, is there an economical way to obtain 2 of these o-rings? I do not have a nearby dealer and prefer to order online. I thought I had seen this in a thread, but am unable to find it.
thanks!
-Neal
If it's not damaged, and it fits snugly in the groove, you can re-use it.
Replacements can be had here:
http://ca-cycleworks.com/products/maintenance/gaskets-o-rings/or-40111a
Or at your local dealer.
lazylightnin717
Check out my recent thread for reference.
http://www.ducatimonsterforum.org/index.php?topic=64382.0
I bought a pack of 5 viton o-rings from McMaster for about 8 bucks shipped to my door. The OEM ring was somewhere around $14 for one...and in my case, it wasn't the right size.
I'd sell you the leftovers I have but depending on where you are, McMaster could have it to your door quicker.
Of course, I would never want to dissuade you from using a site sponsor for OEM parts either  [beer]
Comes a time
Says don't you see
Gotta' make it somehow
brad black
Brad The Bike Boy
http://www.bikeboy.org
I have a cap holder I use for coating tanks. It's been in and out of tanks probably 1000 times.
I had to replace the o-ring once when I used it to remove a failed Kreem job with MEK as the solvent which swelled the o-ring.
Save your money.
