Oberon clutch slave
Started by Silver duck, August 03, 2013, 06:28:01 PM
Silver duck
Any body have any problems installing a Oberon clutch slave with disengagement of the clutch stack. 07 s4r if it matters. It's a 29 mm bore
Thanks
jerryz
I have an Oberon slave on My S4 and its superb  also fitted one to my M750 , they are very high quality , and reduce clutch hand force by about 30%  , have many pals who use them too.
suction bleeding at the slave using either  amityvac or a syringe is foolproof method of ensuring no air in the system which is usually the cause of  insufficient clutch lift ,
also thats the best way to bleed rear brake ....
Silver duck
Thanks ill give mine a shot.
JimmyTheDriver
#3
I have one on my bike, works great.  Hardest part was the bleed, but after a few tries, it's been flawless since.
Yours is getting stuck engaged?  I remember there being a little push rod extender that you can put in the slave, did you use it?  The pushrod, or whatever its called, on the S4R does not need it.
-Jim
Silver duck
Didn't install it yet I seem the little spacer
